Sadly, the configuration files are not compatible and you will need to reprogram the BLGW. It's worth the effort, though. You'll find that the programming is quite fast now that you've already put the though into the MLGW programming. Also, the BLGW can quickly find and add trigger sources in most cases with one click.
Thank you. Clear enough.
