Just to let you all know the technical gremlins have packed up and gone home, so tonight Ladies & Gentlemen... there'll be a Prize Draw!
Kick Off is at 9pm, UK Time, which is just over two and a half hours from now.
Good Luck to those who are entered! Do you think you're a winner this evening??
Lee & The BeoWorld Team
9 LEE:Do you think you're a winner this evening??
Good luck all !
