Beoplay A6 Bluetooth problem
chris
Posts 79
chris Posted: Mon, Apr 16 2018 11:05 AM
Hello
I have a Nokia 8  phone which is android. Whenever I try to pair the A6 with the Nokia 8 the beoplay A6 rejects it. It simply refuses to pair with the Nokia. Beoplay support told me that they cannot confirm compatibility and are sincerely sorry for the inconvenience.
I thought all beoplay products are android compatible and I don't know what I should do or if there is anything I can do.
Ulrike
Germany
Posts 174
Ulrike replied on Mon, Apr 16 2018 1:15 PM
Sadly that's a known issue with the Nokia 8, Nokia implemented Bluetooth version 5 so maybe there is a compatibility issue.
Are you able to pair your phone with other bluetooth devices successfully and does it work without disconnections and dropouts?
If it works you are lucky because bluetooth issues like that are a well known Nokia 8 Oreo FW bug.
Bugs everywhere No - thumbs down
But what to do ..
How about playing music via Chromecast? Works flawlessly and with much better sound quality, because B&O devices do not support bluetooth aptx code for a better sound.
chris
Posts 79
chris replied on Mon, Apr 16 2018 9:16 PM
Hi thanks yes I have paired my Nokia 8 with various speakers like Bose and Sony works fine.
My A6 doesn't like my Nokia. Spotify connect works flawlessly but I have files downloaded on my phone that I'd like to listen to..oh well...
chris
Posts 79
chris replied on Mon, Apr 16 2018 9:18 PM
You say beoplay doesn't support aptx Bluetooth but I'm sure I read somewhere that the S3 speaker supports this...
Ulrike
Germany
Posts 174
Ulrike replied on Mon, Apr 16 2018 9:52 PM
Just some of them, check it out here:
https://www.aptx.com/products?field_product_brand_tid=254
Page 1 of 1 (5 items) | RSS
