New signal cable for Beogram 1700
paul_f
Posts 12
Silver Member
paul_f Posted: Thu, Apr 19 2018 7:05 AM
I have a Beogram 1700 that needs a new signal cable as it had been cut very short - I think for a RCA conversion as the pins were different to stock.
Does anyone know a source of the correct cable (ie shielded signal wires and then a separate shield).
I tried using an off the shelf DIN cable that had 4 cores and a shield (so joining 2 of the cores for signal ground) but I get a lot of hum.
Paul
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Paul,
The exact cable layup used in the older Beograms isn't available new as far as I am aware, but there are some very close matches to this that are still available.
If you are confident with soldering the cable into the Beogram yourself, please drop me a line via my sponsor link below and I will be pleased to advise on the cable options available.  If you prefer to get a repairer to do the work for you, I can recommend AVA Services in Crawley, who are approved B&O repairers.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (2 items) | RSS
