Hi all!
I got my hands on a good pair of Beovox S45-2 speakers.
Given the fact that the speaker stands are hard to come by, I've build them myself.
I've found a most descriptive image with all the measurements besides the angle under which the spine is attached to the base of the stand. Does anyone know what is the angle I'm looking for?
Thanks!
The angle is 5 degrees on mine.
Jacques
5 degrees is about right
Thanks for a swift response!
I think my Google is very weak and a picture like you mentioned is not to be found - by me at least.
Would you mind sharing the one you have, as I seem to be getting mixed results when searching. S45 stands are easy, S45-2 - not so much.
Thank you hugely!/Steffen
get this post from the old, archived forum. There's a nice drawing with the required data.
Or try this old thread: Link
Ralph-Marcus
