Hi
With the Bang & Olufsen app you can go into the products section and pair an Essence remote with Bluetooth to either BeoSound 1 or 2.
The BeoSound 1 is ongoing and the black is simply a limited edition.
Regards
Opman
steve1977:Great. Is stereo pairing possible?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
chucky:Got the beosound 1 today, Black . Can anybody shad a light on this, I cannot join with an Essence MKII. The other way around it works but the Essence MKII doesn’t see the beosound. With the core any of the 3 no problem. Tx Chucky f From Beovision to doorbel...all B&O what rings.
chucky:https://theaudiophileman.com/beosound-1-bang-olufsen-news/ I sold my beolit 17, no support on multiroom. I like integrated sollutions so when I walk outside I just push a button. Black.... does this mean it will be replaced, as B&O often make one final edition in black and than discontinue? ETA 7 May.
ETA 7 May.
They may be updated with mic's this Fall (voice control). B&O's strategy to keep products fresh seems to be a new color every year or so, but the black was a limited edition as stated and the dealers had to pre-order - and once the critical mass was reached they went into production. If you want one in black, I would recommend walking out of the store with one if possible - don't think twice or blink, otherwise it will be gone. Great that B&O kept the original sticker price even if it is a limited edition.
Roger
Chris Hassell:Got mine in Black today. Don’t know where I’m going to put it but I Love it!!!! BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
You have an on/off button under the unit.
Why don´t you keep it connected to mains when not in use, and just disconnect when you want to move it around?
chucky:Hi, it seemd that the bs 1 keeps connecting, plop plop, it was annoying last week so I turned the sound off. I use it only on occasions in the garden . Now it is empty, no juice. That will help when I want to use it. How can I prevent it from popping but keeping it in my nl network without running out of power. Tx Chucky From Beovision to doorbel...all B&O what rings.
Hiort:You have an on/off button under the unit. Why don´t you keep it connected to mains when not in use, and just disconnect when you want to move it around?
chucky:Ok I am a bit spoiled I have a set of beolabs in every room, bit if you want to use it as a link speaker you go nutssss So yes just switching of is a temp sollution bit for customers who want to use it as a link it isn’t. I would not want to reconnect. From Beovision to doorbel...all B&O what rings.
