BeoGram 1203 single channel sound
This post has 4 Replies | 0 Followers
Christian Leicht
Aarhus, Denmark
Posts 72
Christian Leicht Posted: Mon, May 7 2018 6:22 PM
Hi there!
I am restoring an BeoGram 1203. It will only play sound in the left speaker. I have checked that the connections is soldered correctly to the "motherboard" so the issue must be in the tonearm.
Is there a guide on how to dissesamble the tonearm and resolder the connections?
Thanks,
Christian
Kind Regards,
Christian Leicht
https://leicht.io - B&O Custom Parts & 3D Models
Søren Mexico
Mexico City
Posts 6,411
Take off the pickup and check resistance from the 4 pins to wire solder points, if ok check your pickup
Christian Leicht
Aarhus, Denmark
Posts 72
Søren Mexico:
Hi Søren,
I should have mentioned that i have tried with 2 different pickups, and checked the connection from the DIN to the "motherboard".
I will try your suggestion and return. Thank you.
Kind Regards,
Christian Leicht
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, May 8 2018 7:11 AM
Do the checks with the deck in PLAY mode to avoid the muting contact shorting everything.
Christian Leicht
Aarhus, Denmark
Posts 72
I cleaned all the oxidated connections and everything is working. Thank you.
Kind Regards,
Christian Leicht
Page 1 of 1 (5 items) | RSS
