Am I stupid or what? I can't find any way to edit my post!
Jacques
No edit that I could find yet.
Don't think it is there.
Should be a button like the old forum rather that in the pull down!
i have posted feedback to Keith about the edit button
Eclipse 65V1-32Beosound M5Essence MK2BLI
See other thread - press the MORE button and edit will appear.
Peter
Peter: See other thread - press the MORE button and edit will appear.
It has been ON/OFF at different times... Sure it is just clean up.
It is present now.
I can confirm that EDIT should be in the MORE pulldown
Regards Keith....
Keith Saunders: I can confirm that EDIT should be in the MORE pulldown
No, it does not, at least not for me as a lost 3 stars member, can not reply on the General forum member and some other things
Brengen & Ophalen
Hi Leslie!
I can certainly edit my first post here!
As an aside, making some progress on the tuner, have you seen the posts?
Who's the blonde?
chartz: As an aside, making some progress on the tuner, have you seen the posts?
Yes I did, good job!
chartz: Who's the blonde?
"Makepeace" long time ago (had a crush on her)? Our age and still looking pretty
Ah, okay. Glynis Barber is totally unknown this side of the Channel!
