Beosound 1 and Beogram Turntable
This post has 3 Replies | 0 Followers
chris
Posts 79
chris Posted: Wed, Mar 7 2012 10:36 AM
Can I hook a Beogram turtable to my Beosound 1 and listen to my lp's?
It should be possible i think... And would the sound be good??
Heribert
Vorarlberg / Austria
Posts 804
Heribert replied on Wed, Mar 7 2012 10:55 AM
depending on the turntable you need some pre-amp. Check out the solution with Steve from Sounds-Heavenly (on o fht esite sponsors). The make very good quality cables at reasonable prices. He will have your solution
BV 11-46  / Beoplay V1 -40 / Apple TV 1+3 / Beosound Essence MK2 / BL3 / 2* BL11 / BL 6000 / BL 12-1 / BL 2000 / 3 * Beo4 /BL Converter 1611
chris
Posts 79
chris replied on Thu, Mar 8 2012 12:41 AM
Thanks I want to use the Beogram 7000 turntable. Is it possible just using a cable? Why would I need a pre amp?
The beosound 1 has it's own amp.
chris
Posts 79
chris replied on Thu, Mar 8 2012 11:52 AM
i'm good to go. the beogram 7000 has it's own amp so it's plug and play. great news.
Page 1 of 1 (4 items) | RSS
