Copy configuration from one BEO5 to an other Beo5 controler ?
This post has 9 Replies | 2 Followers
jga5370
Posts 4
jga5370 Posted: Sat, May 12 2018 12:18 PM
How can I copy configuration from one Beo5 to an other empty Beo5 controler ? I have configuration tool software but do not know how to load existing  configuration from the first Beo5.;
Thank you
Weebyx
Denmark
Posts 1,213
Weebyx replied on Sat, May 12 2018 4:47 PM
jga5370:
Thank you
Sorry, that is not possible. You cannot get a configuration back from an already loaded Beo5. You need to start over from scratch.
/Jacob
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
Was the Beo5 Configuration originally done by a B&O Dealer?
Regards Keith....
jga5370
Posts 4
jga5370 replied on Sun, May 13 2018 11:17 AM
Yes, it was.
Silou
Switzerland
Posts 465
Silou replied on Sun, May 13 2018 11:44 AM
By this way he can do it
Keith Saunders
Posts 5,495
jga5370:
Yes, it was.
What is the serial number of your Beo5?
Regards Keith....
jga5370
Posts 4
jga5370 replied on Sun, May 13 2018 9:50 PM
Serial number of my BEO5 is: 20571151
Thank you
TWG
Posts 1,672
TWG replied on Mon, May 14 2018 6:36 AM
It is possible!
you'll need of course the old configuration file of your old Beo 5 remote.
Than you have to use the new Beo 5 remote with the config tool and set up a simple configuration (e.g. one room one product) so that the config tool can generate a config file for the new remote and you have to save it. Close the config software.
Afterwards you can copy the old configuration file of the old remote into a folder and rename it to the exact name of the NEW config file of the NEW Beo 5 remote. As far as I remember the file names consist of the remotes serial number. Copy the renamed file into the file folder (somewhere like C:\Bang & Olufsen\config tool...) where the simple config file of your new Beo 5 is found. You have to look up where the software is installed on your computer. Replace your created Beo5 file with the renamed file of the old Beo5. When you start the config tool after this procedure with the new Beo 5 you should see your complete old configuration of your old remote (just select the appropriate serial number if it doesn't work automatically) and can edit and transfer it to your new remote.
jga5370
Posts 4
jga5370 replied on Mon, May 14 2018 3:29 PM
Thank you very much for your detailled answer, but I do not have yhe old configuration file - I just have the old Beo5 configured remote.
Anyway, your message will be very helpfull anyway
Best regards
TWG
Posts 1,672
TWG replied on Tue, May 15 2018 6:54 AM
You're welcome. Was your remote programmed by a dealer? Maybe he has a configuration file of your old remote or it is stored on a Bang & Olufsen server!?
Page 1 of 1 (10 items) | RSS
