Beosound 35 and Deezer/Tunein
DavidSJones76
Posts 39
DavidSJones76 Posted: Sat, May 12 2018 2:36 PM
Hey guys,
I hope you are all well.
I recently bought a Beosound 35 and it's great, especially when connected to multi-room. However, that is the only way I can listen to it, because it wont let me login in to either my Deezer or Tunein accounts. It just says "Sorry login failed"
It means I cant access my content just through the 35. I mostly listen multi-room, so this is not a big issue, but I just wondered why I can't login to Deezer or Tunein. I am entering the right details too, before any one asks lol.
Can anyone help?
Thank you in advance
David
CB
> You are Here <
Posts 1,762
CB replied on Sun, May 13 2018 12:40 PM
Hey David
Congratulations on your BS35, it’s a great piece of B&O art Smile
Long ago, mine did that too, and If I remember correctly (it’s not sure...), a reset to the factory settings solved the issue.
Is the latest software installed?
DavidSJones76
Posts 39
Hey,
Thanks for your post. I've done several factory resets to try and resolve this and nothing changes.
The update version number I have is 1.4.311. It says my BS35 is up-to-date.
Any ideas?
BTW you're right that it is an awesome bit of kit
Thanks in advance
David
Ruud
NETHERLANDS
Posts 65
Ruud replied on Tue, May 15 2018 6:56 PM
David:
Any ideas?
Thanks in advance
David
He David
No problems with tunein or spotify with my BS35. But the beo app tells that my sw is also up to date with version 1.16.20033.xxxxx
Beofan with current setup Beovison Eclipse 55, Beosound 35, Beolab 6000, Beolab 11, Beoplay A9 Mk4, Beoplay E6
CB
> You are Here <
Posts 1,762
CB replied on Tue, May 15 2018 9:30 PM
David:
I’m not at home now, but I agree with Beofan, this doesn’t look like the latest release...
Is your B&O account (cloud) ok ?
Did you use the Beotool app to check its state?
EDIT : mine is also 1.16.200.33.xxxx
DavidSJones76
Posts 39
Hey guys,
Thank you so much for taking the time to respond.
I thought it would be an issue with my BS35 not having the correct software version.
No matter what I try though, it all says my product is up-to-date. Using the app or doing it via its IP address all have the same result.
I contact the support section on Bang and Olufsen page the other day asking about this, but i'm still yet to hear back from them.
Thanks again guys.
Take care,
David
Page 1 of 1 (6 items) | RSS
