Hello,
I have purchased a complete second hand BeoSystem 7000.
However, BeoGram 7000 has some issues.
What could be the issue here please? Is it perhaps old grease on the rails that need replacing with new white lithium grease? New belts? (but the arm can move).
Advise really appreciated please.
Regards, BeoMedia
Sounds like the cartridge needs to refurbished to improve the sound quality.
Lack of arm movement could either be duff belt on the servo motor (I suggest you order a belt set from Dillen anyway) or blown bulb or light sensitive resistor in the servo mechanism under the rear of the arm carriage (not difficult to fix but fiddly).
Regards Graham
Hi Graham,
Thanks for the input. Will try this. The MMC is being sent off for refurbishment and I shall check the servo belt.
This forums gives classical B&O equipment a second life
Regards BeoMedia
