I used to use this and had it connected to an ir eye thanks to a cable from Steve at Sounds Heavenly but the pc died and I couldn't get it to work on the new pc so I rewired the ir eye and used an beolink active to listen to music.
Seeing posts on this forum that beoport worked on Windows 10 I recently tried again and it worked this time! Apart from the rewired ir eye back with Steve's cable, any ideas why this won't work.
Paul
