CDX Door issue
This post has 1 Reply | 0 Followers
bigphil
Posts 69
Silver Member
bigphil Posted: Sat, May 19 2018 7:31 AM
Hi I have just bought a very nice Beogram Cdx, it plays fine only issue is the door, it doesn't lift or go down, also the small CD platter doesn't lift when you manually open it.  The eject button releases the mechanism but that's it.  Could this be an easy fix please? Thanks Phil.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, May 19 2018 7:55 AM
If you can hear the motor running, then the belt has most likely snapped or the gear has lost its teeth.
If not, check that it gets power. If no power check the driver circuit and the switches associated with the eject function.
The lower "paddle"-part of the disc lifter plate has probably broken off. You may be able to repair it - else replace it.
Page 1 of 1 (2 items) | RSS
