Connecting turn-table / Beogram with Beosound 1
steve1977
Posts 911
steve1977 Posted: Sat, May 19 2018 2:31 PM
I am considering to buy a Beogram or a non-B&O turntable.
Wondering whether I can connect it with a Beosound 1 or other B&O speakers? As easy as plugging it into the line-in?
Millemissen
Flensborg, Denmark
Posts 14,680
The (old, which I suppose, that you mean) BeoSound 1 has an Aux-input.
You will need the appropriate cable (Steve can provide this), and you must turn on the input
either manually pushing the two arrows around the ’CD’ button or with a Beo remote using ‘A.Aux’.
Depedent on the turntable you will need a RIAA preamp as well.
The new BeoSound has no line-in connection, that could be used.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Steve1977,
MM is correct, you can use a turntable with the old (CD player) Beosound 1, but not the new wireless version.  Most turntable need a phono pre-amp like this one to boost the signal: https://soundsheavenly.com/beogram-record-players/pre-amp-bundle-for-bo-beogram-and-all-turntables
For other Beolab speakers, you will generally need a music system with a volume control connected between the turntable and the speakers to let you adjust the volume.  Please let us know which model of speakers you choose and we can assist further.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
steve1977
Posts 911
steve1977 replied on Sun, May 20 2018 3:10 AM
Thanks for your quick replies. i actually meant the new BS1, but forgot it lacks a line-in. what about BS2 or A9? could i connect a turn table to it? would this make sense?
Posts 2,165
The new Beosound 1 doesn't have a line input, so you can't link a turntable to this.  However, you can use a turntable with either Beosound 2 or Beoplay A9 via the pre-amp mentioned above (there are options to choose the output cable to suit your needs, ie. 3.5mm for BS2 or twin RCA for A9).
Steve.
steve1977
Posts 911
steve1977 replied on Sun, May 20 2018 12:01 PM
Thabks. this is great! i’d assume it would be even better for me to find a record player including a pre-amp? would love to avoid “yet another black box” that needs a power cable and i’ll need to hide away somehow.
Millemissen
Flensborg, Denmark
Posts 14,680
If you are looking for a BeoGram this list might help you:
https://www.beoworld.org/article_view.asp?id=67
steve1977
Posts 911
steve1977 replied on Tue, May 22 2018 4:08 PM
thanks for your help!
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Tue, May 22 2018 8:57 PM
Don't forget that once you have connected a turntable to BeoSound 2 or other product with line in, you can "Multi room" to any other speaker on the same network including BeoSound 1. So you can listen to your vinyl through BeoSound 1 in another room.
It works a treat.
Opman
Page 1 of 1 (9 items) | RSS
