BV7 IR Transmitter
k984942
Posts 49
k984942 Posted: Wed, May 23 2018 3:18 PM
I have my ATV and BV7 connected properly. I see the IR transmitter is working correctly (I used an old digital camera to ensure it's sending a signal), and Apple TV is selected in the connections list. The issue is I cannot seem to control the ATV with my Beo4.
The ATV is flashing to show it receives an IR signal from the BV7, but it just doesn't respond. Of course using the remote that came with the ATV works fine.
Any thoughts?
Stoobietoo
Exeter, Devon, UK
Posts 692
Sometimes the ATV is paired to the original remote control. Go into the settings on the ATV and unpair any remotes.
Stoobie
Stoobietoo
Exeter, Devon, UK
Posts 692
Duplicate post.
Stoobie
k984942
Posts 49
k984942 replied on Thu, May 24 2018 7:48 AM
Thanks SO much! Worked perfectly Smile
Stoobietoo
Exeter, Devon, UK
Posts 692
Brilliant.  It is always good when it is an easy and free fix.
Stoobie
Page 1 of 1 (5 items) | RSS
