beogram 6500 missing record edge
This post has 6 Replies | 0 Followers
cmsammy
Posts 84
cmsammy Posted: Thu, Oct 18 2012 7:14 PM
When pressin play, the arm comes across but stops just short of the record edge. When going back to rest it seems to try and push past rest.
Anyone know how to resolve this
Clive
cmsammy
Posts 84
cmsammy replied on Sat, Dec 1 2012 7:00 PM
Can anyone help me on this
Søren Mexico
Mexico City
Posts 6,411
A good cleaning and lubricating will probably help, also consider changing the belts if not done already
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Dec 1 2012 8:14 PM
There is an adjustment for this in the form of an excentric at the foot of the carriage.
cmsammy
Posts 84
cmsammy replied on Thu, Dec 6 2012 10:09 PM
Belts changed not long ago, I was going for the "open it up and have a look" approach but was hoping for a pointer to something specific before I started.
UPDATE !!
Found both adjusters for 17cm and 30cm set down, both now adjusted to maximum and it's closer but still drops off the record edge, it doesn't try to push past rest on return so some improvement. Could the cord that runs round theses pulleys have stretched ?.
Dillen
Posts 13,191
Dillen replied on Fri, Dec 7 2012 6:54 AM
There is a single adjustment, an excentric, at the foot of the carriage.
Take off the platter, push the carriage left and you can see it.
cmsammy
Posts 84
cmsammy replied on Tue, Feb 5 2013 10:41 PM
Hi Martin,
I'm sure your helped me with a part for my beocord 5500, the drive wire has now unloaded itself, I reckon it must have stretched as no adjustment would get it to reach the record edge.
Can you help with a replacement drive wire for the beogram 6500 ?
Clive
Page 1 of 1 (7 items) | RSS
