Playmaker and Beolink passive
This post has 10 Replies | 1 Follower
badgersurf
Posts 539
badgersurf Posted: Fri, Oct 19 2012 11:10 AM
hi All,
I hope you can help. I am just about to move into a new house and have been looking into how to set the house up with my equipment.
I have a couple of beolink passive amps and was wondering if these could be connected to the playmaker (they have a powerlink socket but all the manuals I have say not to use this). Is it possible to to connect the two?
Toby
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Oct 19 2012 1:12 PM
A Beolink Passive can be used
a) via Masterlink in a link room to connect passive Speakers to your audio master (masterlink used)
b) via Powerlink as an amp to drive passive speakers locally  (masterlink not used)
This is how I used to run beolink passives.
Therefore I don't see any issue using the powerlink socket (via RJ45 Adapter) to attach to the playmaker.
BUT - have not tried this - I remember the powerlink cable has to be fully wired (8 wires?)....
So, maybe someone can confirm??
Ralf
Yendys
Sydney
Posts 312
Yendys replied on Fri, Oct 19 2012 1:32 PM
Sound heavenly one of the sites sponsors does have a cable that will allow playmaker to connect to a passive. It works well
badgersurf
Posts 539
Thanks for the quick replies.
Now just have to move into the new place and get it all set up.
Toby
Raeuber
Germany
Posts 2,542
Raeuber replied on Fri, Oct 19 2012 2:03 PM
I have my beolink passive connected via masterlink. Can I use both sockets, masterlink AND powerlink, to connect a playmaker? Of course I don't use masterlink and powerlink at the same time in this case.
/Räuber
Millemissen
Flensborg, Denmark
Posts 14,680
Hi Räber,
if you can live with unplugging and plugging-in cables all the time - then:YES.
I wouldn't Angry
Plug the Playmaker into your Audiomaster(Aux or A.tape, and enjoy in all ML-rooms,
Or: buy a BeoLink Active - plug that into MasterLink, and use your BeolinkPassive as an amplifier.
Then use the Pc-in on the Activebox for the Playmaker  - you can buy the cable(s) at your B&O-dealer.
See my Playmaker-setup (date: 03.10.2012). Sorry it is in danishUnsure - but with lots of illustrations.
www.hifi4all.dk/forum/forum_posts.asp?TID=46053&PN=0&TPN=235
Greetings Millemissen
Raeuber
Germany
Posts 2,542
Raeuber replied on Fri, Oct 19 2012 3:48 PM
Thanks, Millemissen!
OR (my solution): Using an Apple TV at the videomaster. With an extra optical-to-coax-converter I can also hear sound with Beovision in linkroom and with Beolink passive. So no Playmaker is needed, it was only a question for me.
/Räuber
Millemissen
Flensborg, Denmark
Posts 14,680
To every question there is a reply Confused
Might be of some inspiration to other users!
N.B. The Playmaker has other features than a ATV - it is a different product.
P.S. Which DAC are you using?
Gruss Millemissen
elephant
AU
Posts 8,219
elephant replied on Sat, Oct 20 2012 4:25 AM
Millemissen:
Hi Räber,
I wouldn't Angry
Thank you ! That was a veery interesting read - especially your post :-)
Here is a translation link to it !
ENGLISH TRANSLATION :-)
BeoNut since '75
Millemissen
Flensborg, Denmark
Posts 14,680
Hi Ed, thank you for your kind words.
Especially - thanks to the Playmaker and the Squeezeserver -  I am very pleased with how easy it is to have access to all my FLAC-files via iPad throughout the whole house.
N.B. I hate google-english. Much of it is very incorrect googlated - but I do not have the time to translate everything myself.
But thanks anyway for posting the link.
elephant
AU
Posts 8,219
elephant replied on Sat, Oct 20 2012 10:57 AM
Millemissen:
Yes, it is probably 80% accurate ... but that is good enough to "read between the lines" Smile
And it was my pleasure
BeoNut since '75
Page 1 of 1 (11 items) | RSS
