BC 9500 Metal Panels
This post has 12 Replies | 0 Followers
auric
Posts 90
auric Posted: Mon, Oct 22 2012 7:28 PM
Any idea where I can get a replace door for the cassette side of the BC9500?
The one I have is scratched.
Thanks,
Derek
Steffen
Denmark
Posts 1,408
Steffen replied on Thu, Oct 25 2012 9:41 PM
Since nobody have answered yet...
I guess the only solution is to search the net for a non functioning BC9500 or 9300 and use that as a donor.
The postage may be quite expensive though, if you do not find one nearby where you live.
And it does require some technical skills (and a lot of patience) to replace it.
Orava
Finland
Posts 991
Orava replied on Sun, Oct 28 2012 10:38 AM
Maybe, if someone have one, one will keep it, might someday need it. I would be happy to get even some scrathed one, as I need only plasticparts...
Bob
Charente, France
Posts 418
Bob replied on Sun, Oct 28 2012 11:46 AM
As others already said - they're not easy to find (if not mistaking support by B&O was stopped as well for those) - but you may try either live with the fact, that they not perfect, but working or to scatter net until you find some I've seen set not long ago on eBay,
That said I myself look for glass panel for bc8500 months now without luck, as the economic situation progresses it'll be more "uneconomical" to repair units offered through eBay and other media's.
all the best
bob
auric:
Thanks,
Derek
Don't worry - be Happy
Mikael
Sweden
Posts 58
Mikael replied on Sun, Oct 28 2012 12:54 PM
Hi Derek,
I would say your best bet is on Ebay or ask our fantastic resident obsolete B&O parts supplier Leslie.
They do tend to show up in various condition every now and then. You are probably lucky if you find one that sells the cassette door only. They usually go as a set (doors + the center piece).
Good luck,
Mikael
Beocenter Overture | Beolink passive | CX100 | CX50
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Sun, Oct 28 2012 3:19 PM
Whistle
Brengen & Ophalen
auric
Posts 90
auric replied on Mon, Oct 29 2012 8:18 PM
Is it true that all 3 panels need to be replaced because the stainless steel color many not match?
Steffen
Denmark
Posts 1,408
Steffen replied on Mon, Oct 29 2012 10:04 PM
auric:
I would doubt that.
The quality of those polished aluminum panels (they are not stainless steel)  from B&O is very high.
I have never tried to put two BC 9500's next to each other to compare...But I have a Beosystem 4500 (receiver, tapedeck and CD-player) where I have replaced the Beocord and Beogram CD several times. There has never been any visible differences, even if they were manufactured in different years.
Bob
Charente, France
Posts 418
Bob replied on Wed, Oct 31 2012 12:50 AM
It may be slight differences however - depends on use and environment panels was imposed to, but would have little if any significance ;)
b
auric:
auric
Posts 90
auric replied on Wed, Oct 31 2012 12:53 AM
Thanks guys.
I'll be patient and wait for a door to appear :)
Dennis
Denmark
Posts 627
Dennis replied on Wed, Oct 31 2012 8:07 AM
I think Leslie's "Whistle" was meant as hint to you, Auric! Wink
- Dennis
Bob
Charente, France
Posts 418
Bob replied on Wed, Oct 31 2012 10:45 AM
Yeah, I think so
Leslie is very nice guy and sells anything for right price ;)
b
Dennis:
- Dennis
Leslie
Posts 5,423
Silver Member
Leslie replied on Wed, Oct 31 2012 11:59 AM
Dennis Left Hug and Bob Left Hug
Brengen & Ophalen
Page 1 of 1 (13 items) | RSS
