When i plug the Beomaster 7000 in the volume indicators light up but it doesn't seem to do much else. If i hit the "turn" button on the turntable it will spin but when i hit 33 nothing happens. And when i try to select other sources nothing seems to happen either. Any ideas?
Your Beomaster will need a service, it appears. Something related to the CPU reset or power supply is my guess.The Beogram will not start by pressing 33. Press start instead (on the front, right side).It won't start without a record on the platter.
