I can't really see where the loose wire is, even in the picture where it should be in focus.Is it the grey wire? If so I do remember it goes to the playhead I believe.
Here you'll find some pictures of a electrically working unit, maybe it would be of any help for you.
Good luck.
https://archivedforum2.beoworld.org/forums/t/26380.aspx
There is a spade connector in front of the tapedeck to the bottom right(when looking from behind), just about where you can see wire in your picture. You need to remove the front panel, and possibly the tapedeck again, to get to it. It is kind of "hidden" but you should be able to find if if you get some good light in there.
It is located along the guide for the glass and wires, so make sure to connect it so the wires can run free. If you remove the tapedeck you can see it clearly.
/Jacob
Weebyx:There is a spade connector in front of the tapedeck to the bottom right(when looking from behind), just about where you can see wire in your picture. You need to remove the front panel, and possibly the tapedeck again, to get to it. It is kind of "hidden" but you should be able to find if if you get some good light in there. It is located along the guide for the glass and wires, so make sure to connect it so the wires can run free. If you remove the tapedeck you can see it clearly. /Jacob
Witam Prosze podpowiedziec jak ma byc umieszczony pasek napedowy odtwarzacza kaset w ouverture ..?
