Another ebay BM4400
This post has 27 Replies | 0 Followers
Craig
Yarm, United Kingdom
Posts 2,040
Silver Member
Craig Posted: Sat, May 26 2018 3:22 PM
Cant help myself.......though I really will need to sell off some of these amps, my girlfriend is beginning to despair every time the postman calls ;~)
This one looks in fairly good shape on the surface............
Craig
Posts 2,040
Silver Member
Craig replied on Sat, May 26 2018 3:24 PM
One of the side panels has had a bit of a moment at some time in its career....
Craig
Posts 2,040
Silver Member
But it is recoverable
Craig
Posts 2,040
Silver Member
The screws securing the lid show signs of removal at some point, but the inside looks untouched....
Craig
Posts 2,040
Silver Member
Lots of dust and cobwebs....
Craig
Posts 2,040
Silver Member
She came with the usual "spares or repair" description.....with the added advice that the lights come on but nobody is at home!.....time for the variac.
Craig
Posts 2,040
Silver Member
Craig replied on Sat, May 26 2018 3:37 PM
Pulling very little current....as the power is applied the power lamp starts to glow as does the overload lamp, both pretty much in unison as the power increases the cut out relay clicks in and the the overload lamp is extinguished.....so it's living up to its description ;~)
Peter
Earsdon
Posts 11,991
Peter replied on Sun, May 27 2018 8:24 AM
I think we need to set up 4400 anonymous! " My name is Craig and I am a 4400olic - I have not repaired a 4400 for 1 day!"
I do have a couple of challenges for you but will wait till you have got this 4400 out of your system! Big Smile
Peter
h1npw
West Bridgford, Nottingham.
Posts 1,130
h1npw replied on Sun, May 27 2018 12:23 PM
Hi Craig
i would be interested in buying one of your refurbished 4400 when you get round to off-loading one.
Cheers
Nigel
Craig
Posts 2,040
Silver Member
Craig replied on Sun, May 27 2018 12:46 PM
Nigel
You have just made my girlfriend a happy woman......I have three units sitting in my workshop/dining room, I will email you with the pics and description of each and you can choose which one you prefer.
Craig
Craig
Posts 2,040
Silver Member
Ok...had a little play around this morning, with the variac still connected so I could power up gently each time, and discovered that removing plug 11 from PC5 didnt stop the overload relay clicking in, replaced it and pulled plug 12...still the overload relay clicked in, pulled them both and no overload relay. So a little deflated, because I thought this would identify the rogue channel I set to measuring the voltages as I slowly increased the supply voltage. I found that on the right channel the DC voltage measured at the junction of R279 & R279 was negligable.
Craig
Posts 2,040
Silver Member
However the same measurement on the Left channel revealed DC was pouring out.....
Craig
Posts 2,040
Silver Member
Craig replied on Mon, May 28 2018 1:38 PM
So this is the source of the DC thats energising the overload relay, what I dont understand is why when I disconnect the left channel power supply the overload relay still clicks in?.....I tested this out on a working unit and when a power supply plug is pulled from either channel the relay clicks in.....I cant see how this is happening......words og advice required here ;~)
Craig
Posts 2,040
Silver Member
Craig replied on Mon, May 28 2018 1:43 PM
Quick check of the power transistors revealed 0IC102 & 0IC103 where shorted, popped a couple of replacements in and slowly powered up again, overload lamp cam on and stayed on...overload relay remained de energised....so bit of progress.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, May 28 2018 3:11 PM
The connections to the fault switch circuit is not interrupted by pulling P11 and P12.
Only the power supply and the outputs are.
To separate the fault switch, you would have to lift R46 or R47 respectively, but as you found out there are other (and much safer!) ways
to diagnose problems in the output stage.
Craig
Posts 2,040
Silver Member
Thanks for that, though I'm still struggling a little with this. The understanding I have of the protection circuit is that the overload relay will be energised by either DC Volts biasing TR16 or by the resistance of R40 going high due to high temperature on the power transistor heat sink.
That being the case why when I disconnect P11 or P12 (but not both) does the overload relay energise, clearly im missing something here?
Craig
Craig
Posts 2,040
Silver Member
However pulled OIC100 and OIC101 (tip141) and this is what I found.....
Craig
Posts 2,040
Silver Member
Replaced both with good spares and also changed out all the transistors in the power amp along with C138 and D104/105.....was rewarded with a good looking quiet current reading of around 5mV when I slowly powered up with the variac....no smell of burning shelac or smoke signals
Craig
Posts 2,040
Silver Member
and the other channel..............will test it with a signal tomorrow and if all is well will start to strip and clean and recap.
Craig
Posts 2,040
Silver Member
Craig replied on Thu, May 31 2018 7:30 AM
Hooked up my Ipad and squirted Van Morrison in this morning.....sounds very nice, as they all do. I will replace the "good spare" TIP's with new ones along with everything else....as we now know once an event has occured scars will remain and the "good spares" have been through trauma in a past life which is how they came to be what they are.
Beo_Jean
QC, Canada
Posts 334
Beo_Jean replied on Thu, May 31 2018 11:12 PM
Craig,
To me, this amp is just another example of problematic output transistors.  I don't see evidence, in your case or mine, where other transistors or components caused the output transistors to fail.
The Texas Instruments TIPs are problematic or the heat transfer from the output transistors to the modular heatsink is the problem and better mating surface is required!
BTW, I got your email, I will revise my bill of material (BOM) for this project send it to you by the end of the week!
Best of success!
Craig
Posts 2,040
Silver Member
Craig replied on Fri, Jun 1 2018 7:40 AM
Jean
Thanks for that, this will be the last of the BM4400.....I'm about saturated now. Though I would like to make it a thorough job so will replace all the power transistors as opposed to just the destroyed devices, I think the film capacitors will be a nice touch.
Regards Craig
Craig
Posts 2,040
Silver Member
As there is a debate as to the virtues of silicone pads vs mica shields, and as the shields I have removed are still in good shape I'm going with them, they dont look as neat as the pads it's true and they are quite messy.....but they have stood the test of time.
Craig
Posts 2,040
Silver Member
This reminds me of quite afternoons in the office playing tetrus................
Craig
Posts 2,040
Silver Member
Craig replied on Sat, Jun 9 2018 4:10 PM
I didn't know these film capacitors had no polarity (wont come as a surprise to many) until now.....quite a job getting them to fit, had to be a bit creative here and there.
Craig
Posts 2,040
Silver Member
Moving on....completed work on the pre amp.
Craig
Posts 2,040
Silver Member
Had to replace the stereo decoder chip here, this was confirmed by swapping the board with a working piece when I was getting no FM radio function, replacing the IC corrected the problem....this is the second one of these I have had to replace. Still got a couple of caps to change followed by the pots one at a time.
Craig
Posts 2,040
Silver Member
slowly moving on......
Page 1 of 1 (28 items) | RSS
