Order Beosound Core with IR?
This post has 25 Replies | 3 Followers
stampfki
Posts 138
stampfki Posted: Sun, May 27 2018 8:29 PM
dear all,
Where can I order the IR version?
Cheers
Pat
Posts 152
Pat replied on Mon, May 28 2018 9:12 AM
Any B&O dealer?
Roger
Norway
Posts 417
Roger replied on Fri, Jun 1 2018 11:23 AM
The Core has IR support now - but in a transition period, a store might have both versions available. The IR support is great news for BL5 owners, too.
Roger
elephant
AU
Posts 8,219
Roger:
Roger
How can we tell the difference between the two variants ? I seem to remember it’s not obvious ...
BeoNut since '75
chucky
Posts 331
chucky replied on Sun, Jun 3 2018 12:00 PM
No, I have 2 with IR. the DPL port is used but it still says DPL not IR.
I do have to say it works fine.
Roger
Norway
Posts 417
Roger replied on Mon, Jun 4 2018 7:40 AM
The old one became obsolete in mid-May (ie sold out from DK). The new one has the following type no. 3051 (replaces type no. 2797)
Roger
Aussie Michael
Melbourne, AU
Posts 3,730
I am confused.
Is the older one an IR Core?
And the newer one wasn’t IR but is now?
Thanks,
AM
Roger
Norway
Posts 417
Roger replied on Mon, Jun 4 2018 1:50 PM
IR was a feature requested at the very first dealer meeting after the launch, but it took its time before they got around to launching it.
But just to be clear as mud: the old one did not have IR, the new and current one does have it. It is a very nice device now for owners of the BeoLab 5 as they can use the latest technology to stream and listen to music.
Roger
Barry Santini
New York
Posts 543
Hi
How does that work when a Beolab 5 needs a CD signal to use the SPDIF input?
B
Millemissen
Flensborg, Denmark
Posts 14,680
Roger:
Roger
Very interesting indeed.
I suppose, that you mean the possibility to connect ‘via digital’?
Could you write a few words about how to connect and control - does a small guide exist?
Normally you will have to use the CD command to open the BL5 for the digital connection.
So....how are the BL5’s activted, when connected to the Core?
Do you have to connect via ‘digital out’ and via PL from the Core as well?
Millemissen
Flensborg, Denmark
Posts 14,680
Ouuups - Barry beat me on that question ;-))))
David
Dubai, UAE
Posts 27
David replied on Mon, Jun 4 2018 2:35 PM
I just set up a new Core with Beolab 5's. The speakers power up the Core is activated via the app. As far as I'm aware, no need for the digital out connections to be used in this configuration.
Sound quality is brilliant via Spotify!!
Barry Santini
New York
Posts 543
How is your Core connected to the BL5’s?
Roger
Norway
Posts 417
Roger replied on Mon, Jun 4 2018 3:34 PM
The recommended setup is to use the digital end-to-end signal from the Core to the BL5 (via optical-to-coax-converter) and at the same time use the PowerLink connection in parallel to maintain data communications. This setup avoids static noise.
Roger
Barry Santini
New York
Posts 543
Roger:
Roger
How does the BL5 get to know to use the SPDIF input?
Roger
Norway
Posts 417
Roger replied on Mon, Jun 4 2018 9:00 PM
The BL5 will give priority to a signal received on the SPDIF socket over PowerLink.
Roger
Millemissen
Flensborg, Denmark
Posts 14,680
Thanks Roger - very helpfull.
A set of BL20 or BL18 via SPDIF driven by the Core would also be nice ;-)
carlito
Posts 239
carlito replied on Tue, Jun 5 2018 7:53 AM
Roger:
Roger
Are you sure? With a Beosound 9000 / Beocenter 2 setup the only possibility to activate SPDIF was to use CD as source. That's why I was using my BL5 in Option 1 (Volume Control via Beo4).
Roger
Norway
Posts 417
Roger replied on Tue, Jun 5 2018 8:03 AM
You are correct - a better way to explain it is by example:
The BeoSound 9000 and BeoLab 5 were designed for each other: Listening to radio and the speaker signal would be carried through the PowerLink only, activate CD and the BS9k would get this data communicated through the PowerLink and would give preference to the SPDIF (if present) - but would still work in "radio mode" if no digital signals were present.
Roger
Millemissen
Flensborg, Denmark
Posts 14,680
That would mean, that only the source, that can be activated via the CD command throught the ir/Core, would activate the digital connection.
Any other source/command would ‘play’ through the analog/PL.
According to the list of ir-commands for the Essence (would be the same for the Core, I suppose), that would be activating ‘Spotify’.
http://bogoda.custhelp.com/app/answers/answer_view/a_id/13315/~/hvordan-aktiverer-jeg-kilder-ved-hjælp-af-beoremote-one-eller-beo4%3F
Not very usefull for most Core users ;-(
So - we are still waiting for activating the DPL port for a pure digital output....and for the fitting speakers.
Not very usefull for the current BL5 users, I know.
(And how would we connect the ir-eye in that case?)
David
Dubai, UAE
Posts 27
David replied on Tue, Jun 5 2018 8:56 AM
It's connected using cables I bought from Steve at Sound Heavenly.
The required cable is Old DIN Powerlink (for the BL5 end) to RJ45 Powerlink into the Core. Then you connect a traditional DIN Powerlink from the same Lab 5 to the other Lab 5.
David
Dubai, UAE
Posts 27
elephant
AU
Posts 8,219
Millemissen:
Quite correct.
My BL20s are :)
BeoNut since '75
David
Dubai, UAE
Posts 27
Don't want to hijack the thread but see attached for owners of Beolab 5's who want to connect to Core.
tigerisak
Posts 124
When will the BeoRemote One BT work on the Core?
Millemissen
Flensborg, Denmark
Posts 14,680
David:
Thanks David.
Now all we need is that ‘little extra’ information from Beowise.
It still is a question, how the BL5’s turn on.....when they need the CD command for opening the coax-in.
Page 1 of 1 (26 items) | RSS
