Listening Room design
This post has 11 Replies | 3 Followers
tom555
Posts 19
tom555 Posted: Mon, Jun 4 2018 7:03 AM
Thought people might be interested in my new listening room.  This has been an interesting project that has taught me a lot about audio and integration but produced a nice result.  I was fortunate enough to have a room that does not have parallel walls which lends itself well to good acoustics.
I worked on the project with Watt Integration who is Arizona's B&O dealer.  I have a bunch of B&O equipment and was hoping to just integrate it in a new configuration with a preamp.  My overall project goal was excellent two channel sound with good surround sound.  To that end, here were my specific goals:
  1. Digital music source goes digital directly to front Beolab 5s without D->A, A->D steps
  2. Analog for Reel to Reel, Cassette, Turntable, etc
  3. Surround sound movies and audio.
  4. My large (250,000 track) digital music library had to be fully accessible from the system
  5. One remote to control everything
We had originally planned to use my Beolab 5s as front speakers and even had the thing set up that way. In the middle of his project, my dealer made me a good deal on a pair of BeoLab 90s so that changed things with the integration,  but the fundamental goals did not change.
High end video was never a requirement for this project.   For me, video is disposable technology that changes every few years so I just bought an inexpensive 4k TV.  Good speakers last a lifetime.
So the Beolab 90s are obviously the front speakers.  They are connected via SPDIF to a Cambridge 851N digital preamp and via analog to an Integra preamp/surround processor.  The Cambridge functions as a digital “switcher” and also streams 24/192 lossless music from both my library and Tidal.  It  has 5 digital inputs.  Connected to it’s inputs are digital sources I want to go directly to the speakers.  One input had to be unused to function as a mute so the Lab 90s would receive no signal when switching to the Integra preamp. It has 3 digital outputs that are live simultaneously.   The outputs of the Cambridge are connected to the 90s via SPDIF and to the Integra preamp via TOSLINK for surround decoding.  This allows playing DTS encoded FLAC files through the Integra and gives a connection to the record bus (see below).  The Integra is connected to the 90s, a pair of 4000s (center)  and Beolab 3s (rear) via analog pre-outs for surround sound.  The Integra has 2 reel to reel players, cassette player, a turntable and various surround sources connected to it.  The Oppo bluray player is digitally connected to both preamps.
Great two channel sound was always the priority so we decided to use Beosound Shapes on the wall as dampers to reduce reflections.  No speakers, no core, just dampers. This was decided before the Lab 90s so I don’t know if they are needed now or not with all the ARC.   But, they work and look cool so they stay.
This is all integrated via a URC remote that controls the lab 90s (beam modes, volume, etc), the two preamps and the controllable sources.  It treats the system as a "whole", talking to different pieces of equipment to achieve different ends.  For example, volume control.  The Cambridge sends digital out at full volume, so I wanted the same buttons on the remote to control the volume on the Beolab 90s when in digital mode and the Integra volume control when in Analog/Surround.
It all sounds pretty simple when I write it here (well not that simple), but it turned out to be more complicated than it sounds.   Some of the hiccups:
  1. Trying to find a remote controllable digital preamp.  My previous set up used a Beosystem 3 but I hated the fact that I had to use a composite video switcher to choose direct digital sources and start the CD player to get it to work.
  2. Integration of the two preamps and lab 90s into an integrated system with single remote control that made sense. Watt Integration gets alot of credit here.  Simple is hard.
  3. Latency of the 90s.  Geoff Martin’s web site was super useful for this info.  Even in low latency mode the 90s are 25ms.  This translates to 8.5m. The Integra only allows distances up to 9m.    Even switching to relative distances didn't get me there.    Still not entirely solved.  My sofa is too close to the Lab90s for technical reasons. I am waiting for a delay box I ordered so we can add that to the rear speakers and then I can move the sofa back.  This will make the listening position less locked in.
  4. Lack of tape outs on modern Preamps.  Wanted to be able to record everything to tape or distribute via Sonos.  We ended up using Integra's Zone 2 for this with a manual switch to chose the destination recording device. Also added a “Record” button added to all sources (including the pure digital) that manages the zone 2 stuff in a more functional way.
Here are some pictures.  Note, this is still a work in progress.  There is no trim on the rack yet and the delay box has not been added. Plus the furniture needs a reboot.  Watt Integration has been great to work with.  This project has been experimental and they’ve been great about helping me experiment. Happy to answer any questions.
--tom
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi tom555,
Very interesting!  I especially love the rack mounted open-reel tape recorders in the custom built alcove......I wish I had thought of this when designing my own listening room!
I have the same view regarding video being the more "disposable" technology when compared to audio, my approach was to use a roll-down projection screen, with a ceiling mounted projector that can be updated in the future as technology moves on.
My speakers are a little more prosaic than yours, with Beolab Pentas at the front and Beolab 3000s on the wall at the rear.  My listening room doubles as a recording studio, so my sound deadening panels share the remaining wall space with various musical instruments........ Cool
After seeing your photos, I now have a serious case of "listening room envy" Big Smile
Kind regards, Steve.
Steve.
www.soundsheavenly.com
marexy
Posts 710
marexy replied on Mon, Jun 4 2018 9:25 AM
Hi
nice B&O  tech  :)
but..isn't a little bit small room?
tom555
Posts 19
tom555 replied on Mon, Jun 4 2018 9:35 AM
marexy:
Hi
nice B&O  tech  :)
Yes, a little bit.  The pictures make it look smaller than it is.  But, it was chosen for a few reasons:
  • No major remodeling required
  • Speakers outlast rooms in my experience so I'd rather have over powered speakers in a smaller room.  Can always remodel later.
  • My wife and I have very different ideas of what moderate volume is Smile  This room is the furthest from the Master Bedroom
  • Contained space - the room is separate from the living room allowing more control over sound quality and containment.
  • Acoustically, the triangular shape of the room is great for sound
  • Finally, the room was originally going to use the Lab 5s.  The 90s went in after I fell in love with Narrow mode.  But even then, IMHO, the Lab 5s are better for bigger general spaces  since they are always in Wide mode.
marexy
Posts 710
marexy replied on Mon, Jun 4 2018 12:36 PM
hm....
you say the W..word :)
I support you and I agree that it is not worth it to put on the edge with the master Jedi :)
Millemissen
Flensborg, Denmark
Posts 14,680
marexy:
hm....
Just show the wife what Reference Level is - anything below is moderate  Smile   Smile
Leif
Middle Jutland in DK
Posts 130
Leif replied on Fri, Jun 8 2018 8:58 PM
"My wife and I have very different ideas of what moderate volume is "
Same here, so I went the doctor - depression news (for me)
½ at right but better at lefr. But nothing came through above 10 kHz
Argh...
/Leif
MediaBobNY
Greenwich Village, NYC
Posts 1,106
Steve at Sounds Heavenly:
The smaller 7" reel one from circa 1980 is a Pioneer RT-707, which I also own.  It was designed for rack mounting, with notches in the faceplate on the left and right sides for the mounting screws
tom555
Posts 19
tom555 replied on Sat, Jun 9 2018 11:01 PM
MediaBobNY:
Good eye.  Yes, RT-707.  The upper deck is a Tascam BR-20 2 track 7.5/15ips recorder.  The Pioneer is 4 track (2 sided stereo) so that's why both players are there.   Above and between the two of them are some rack fans.  Those old R2R players generate a fair amount of heat.
We added the trim to the rack yesterday and had a small issue.  See if you can spot it!  Made it look cool though. We decided to Velcro the trim on so it could be removed in the future.
Just to finish off the rack description, below the Pioneer open reel on the loose shelf is a Sonos Connect, a Raspberry Pi used for control and the a 5 way switch which selects which device is receiving the record  (Integra zone 2) output.  Next is a Nakamichi 3A cassette player.  Below that, rackmounted, is a Denon DR-700R digital recorer/player.  Moving down, the red leds are from the  the digital delay for the rear speakers  which sits next to the remote control unit and an apple TV.
Next down is a Oppo DVD player for HDCDs and a Oppo Bluray player for everything else disc-ish.  Oppo eliminated support for HDCD and I have a bunch of them hence two disc players.  Then there is a 12 port patch panel which has every rear USB connector from all the equipment so it can be accessed.  We also pulled the USB, microphone and SPDIF connectors from the Lab 90s into this panel since they are hard to access.   A Watt box power control is below that followed by the Cambridge 851N and an ethernet switch for the rack.  Finally at the very bottom is the Integra preamp.  Hiding back there somewhere are a Chromecast Audio connected to the Cambridge and a Chromecast Ultra connected to the Integra.   I built this for serious listening and as a bit of a playground.
This is a complicated rack because most everything is multiply connected.   For example, the Denon digital recorder has it's inputs connected via AES from the Cambridge.  It is also connected via analog from the Integra record bus and the Nakamichi outputs (for tape transfers).  Its outputs are connected to the Cambridge via AES.  This lets me record from either preamp and play digital direct.   But this kind of multi connection can lead to feedback loops and nonintuitive modes that integrators normally work hard to avoid.  I accepted Watt Integration's reservations about this but decided in favor of the functionality.   I have a cheat sheet so I can remember how the beast is put together.
The remote control simplifies much of this but for some real oddball modes, the routing will have to be performed manually (like listening to the play head on a reel to reel while recording vinyl).  In these cases, I just have to really think about how to route this stuff (Zone 2 gets phono input.  Main zone gets Reel to Reel)
Almost forgot, in the rear of the room is my Project Classic Turntable and preamp.  It is connected using baluns to the Integra preamp via cat7.  You can see it in this picture with my small but growing record collection and some tapes.
As you can tell, I am a true gearslut. My main goals in these posts is to give people some good solid technical info on how to do a complicated integration like this and to document it for myself in the future.
--tom
MediaBobNY
Posts 1,106
'Can only see that the rack is more professionally fitted in its enclosure in the newer photos.  And I see you have the original Pioneer metal reel.  At one point I noticed they were selling for around $60 on eBay and decided to sell mine.  I never liked it anyway.  If you had the original Nakamichi Dragon I would have noticed that as well.  I had a Pioneer Elite CT-93 cassette deck; very high-end in the day.
bidstonhall
Thailand 5560 miles from Struer
Posts 363
Looks like you had to cut away some of the trim, looks better in actual fact, fabulous setup
tom555
Posts 19
tom555 replied on Sun, Jun 10 2018 11:03 PM
bidstonhall:
Right you are.  We did not measure the reels when we decided on the trim.  The Watt guys are good with all kinds of routers.  Thanks for the positive feedback.   I have done some revision to my recent post with more technical information.  As I added in that post, I am using these posts to give people some technical "red meat" of how a complicated integration was done and using it as a sort of self-documentation tool.  Hopefully, others can benefit from my experience.
Page 1 of 1 (12 items) | RSS
