Is it possible to add BeoLab 2 to basic playmaker setup?I'm currently using it with Lab 4000 and feel like extra base would be nice.If I daisy chain BL4000 to one output from PlayMaker and the other output from PlayMaker to BeoLab 2?
BeoSystem 3BeoSound 9000BeoLab 8000/6000/4000/3500/BL2PlayMakerBeoCenter 9300BeoGram 5500BeoCom1/1600 + BeoTalk 1200BeoCord vx5500
David:Is it possible to add BeoLab 2 to basic playmaker setup? I'm currently using it with Lab 4000 and feel like extra base would be nice. If I daisy chain BL4000 to one output from PlayMaker and the other output from PlayMaker to BeoLab 2?
Hi David,
I would agree with Yendys. Linking the Beolab 2 to the end of the speaker chain will certainly give you more bass, but it won't be anything like as well controlled as if you link the Beolab 2 to the PlayMaker and then connect the Beolab 4000s to the outputs of the Beolab 2. This allows the subwoofer to manage the bass levels to all three speakers, giving you the best sound balance.
You can keep the existing cable from the PlayMaker to the nearest Beolab 4000, simply unplug the speaker and plug this into the input of the Beolab 2 instead. You then just need to add these cables from the output of the Beolab 2 to the Beolab 4000 speakers to get everything working correctly:-
https://soundsheavenly.com/powerlink-8-pin-din-connection/powerlink-mk-3-compatible-8-pin-din-cable-with-4-cores-wired-low-profile-cable
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Simple enough, thank you!
