Beograms
This post has 3 Replies | 0 Followers
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 Posted: Wed, Mar 7 2012 7:55 PM
I know from posts that there are beograms 3000 and 4000 that are sought after but they are rare , old and hard come by. Which of the latter day bg's are the most desirable ?
Peter
Earsdon
Posts 11,991
Peter replied on Wed, Mar 7 2012 8:59 PM
The straight answer is that the later tangential decks are actually all the same, so one can only really differentiate between them by their looks and if they have a built in RIAA. Performance is the same except for the cartridges, which will probably either need replacing or will have been changed already.The most desirable is the Beogram 7000 as it is the last, is not that common and will work with modern equipment as it has a RIAA built in.
There are of course the slightly earlier range like the Beogram 8000/8002. These are in some ways the very best performing Beograms - however they are not quite as well built as the original 4000 series, having quite a lot of increasingly brittle plastic used in their construction.
For good performance at a cheap price, look for the radial tracking Beogram 5000 and the earlier Beogram 1700. I would suggest that these will actually outperform the later tangential decks.
Peter
murcieme
Toronto, Ontario, Canada
Posts 93
I have a Beogram 5000 and love it to death!  There was a slight audible improvement moving up from the also-radial tracking RX, an earlier, more basic design.
I too would love a 4000, 8000, or 7000, but can't seriously say I'd hold out for one considering the joy the 5000 has brought me. :)
Mike
Michael J. Steeves
since 1977
Peter
Earsdon
Posts 11,991
Peter replied on Thu, Mar 8 2012 7:29 PM
The 5000 is beautifully built. As usual with B&O ranges, the first of the series is usually the best built! In the case of the 5000, note the fact that the script on the Beogram matches the other components so that when stacked, the lettering all lines up! Also the splendid light in the lid rather than the totally inadequate light on the tangential models. I stupidly changed my 5000 for a 5005 when I had the 5000 system and regretted it. The Beocord 5000 in the same system is another example of superb engineering.
Peter
Page 1 of 1 (4 items) | RSS
DigiCert Secured Site Seal
