Hey everybody!
I tried to figure out making my own XML codes, but unfortunetly the software LinTronic needs to be bought before I can use it converting my XML files from the Pronto IR Codes.. Since i do only want to try if this works with our system I do not really want to buy a software for testint purposes....
Maybe someone can help me converting my Pronto IR Codes to XML format....
Thanks! :)
A quick GOOGLE brings up a link to the old site. looks complicated but may help
Stoobie
