Beosound 4 and wall bracket for sale
This post has 0 Replies | 0 Followers
rickydon
Posts 5
Silver Member
rickydon Posted: Mon, Oct 29 2012 9:24 PM
The Beosound 4 is the new generation of B&O sleek audio systems featuring CD player, FM and DAB radio, plus direct recording and playback from an SD card slot as well as easy connection for an iPod.  Featuring classic B&O magic, the dark glass door rises with a sweep of your hand to reveal a neat control panel.  A compact, stylish and modern piece packed with features.
The full-graphic display allows for running text and combines with the wheels and buttons on the panel to ensure simple, but effective control of all your extended musical options. In addition to the menu buttons, the turn-and-click navigation wheel offers shortcuts through large amounts of information.  Record music on an SD memory card directly from BeoSound 4, or transfer and listen to digital files from your computer. BeoSound 4 records sound in a quality that the human ear cannot distinguish from CD quality, and supports SD memory cards up to 2 GB.
The Beosound 4 has many placement options.  It can be wall mounted, attached to a dedicated floor stand or simply placed on a table or shelf.
I bought this Beosound 4 as recently as September this year from Iconic AV, the UK’s pre-owned B&O specialists and the only reason for selling this unit so quickly after purchasing it is that after attending a B&O roadshow recently I have decided to upgrade.
Specifications:
Year                                                    2012
Serial No.                                          2282****
Type No.                                           2852
Working Order                               100% Perfect Working Order
Accessories Included                     Mains Power Lead
                                                            DAB Aerial
                                                            iPod Lead
                                                            Wall Bracket
Weight                                              4KG
Casing Colour                                  Black
Overall Condition:
Simply describing an item as mint or as new is commonly overused and open to interpretation and can be totally misleading.  It is great for describing an item at a glance but rarely stands up to close scrutiny.
I have chosen to give a clear and accurate description of every element of the item complete with detailed photos.
This item is in 100% fully working order with no nicks, scratches or flaws so when making a purchase you know exactly what you are buying with nothing left to chance and no nasty surprises.
See below for close inspection:
Side Casing                                       Both Perfect
Top Casing                                        Perfect
Front Casing                                    Perfect
Rear Casing                                      Perfect
Socket Section                                Perfect
Any Unlisted Defects                     No.
Specifications:
Year                                                    2012
Serial No.                                          2282****
Type No.                                           2852
                                                            DAB Aerial
                                                            iPod Lead
                                                            Wall Bracket
Weight                                              4KG
Casing Colour                                  Black
Overall Condition:
Top Casing                                        Perfect
Rear Casing                                      Perfect
Looking for a quick sale so I can buy my new system
Page 1 of 1 (1 items) | RSS
