In reconfiguring my stereo system I noticed that my Beogram 4002 is missing a rubber “foot,” for lack of a better description. The little black rubber pad the Beogram sits on.
Does anyone know where I can get a replacement?
Thanks!
Jeff
P.S. Yes I know I can stick something small under the Beogram, but I’d like to keep it original and proper, as this Beogram is in near flawless condition.
Beogram 4000, Beogram 4002, Beogram 4004, Beogram 8000, Beogram 8002, Beogram 1602. Beogram 4500 CD player, B&O CDX player, Beocord 4500, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 8004, Beocord 9000, Beomaster 1000, Beomaster 1600, Beomaster 2400.2, Beomaster 2400.2, Beomaster 4400, Beomaster 4500, Beolab 5000, Beomaster 5000, BeoCenter 9000. BeoSound Century, S-45.2, S-45.2, S-75, S-75, M-75, M-100, MC 120.2 speakers; B&O Illuminated Sign (with crown & red logo). B&O grey & black Illuminated Sign, B&O black Plexiglas dealer sign, B&O ash tray, B&O (Orrefors) dealer award vase, B&O Beotime Clock. Navy blue B&O baseball cap, B&O T-shirt X2, B&O black ball point pen, B&O Retail Management Binder
Post a pic I have some feet here, from a unit where one was missing.
Ebay offers enough rubber feets/foots in all sizes Jeff!
Brengen & Ophalen
Hi Søren,
Here is a photo of the foot. As it turns out I need 2 feet, the missing two are front right and rear left, which is on a diagonal so the effect is dramatic.
Hi Jeff
I have 2 pieces, not sure if they fit, your pic sucks
Søren, those are for Beomaster 901/1100 and derivates - not for the Beogram 400x series.Jeff needs the same type as sees use on f.e. Beomaster 1900/2400 and Beogram 1000.All plastic - no screws and far smaller than the ones, you show.
Dillen: Søren, those are for Beomaster 901/1100 and derivates - not for the Beogram 400x series.Jeff needs the same type as sees use on f.e. Beomaster 1900/2400 and Beogram 1000.All plastic - no screws and far smaller than the ones, you show. Martin
Thanks Martin, didn´t remembers where they came from, they are free to go to anyone.
Bad luck Jeff, just checked my BM 2400, all feet broken or none existent.I used some glue on feet bought in Home Depot, but you may be able to find some on Ebay, I recommend rubber and not plastic, I have the plastic on some of the items, but plastic make marks and slide too easily.
Well thank you for trying! The effort is most appreciated!!
I agree, the photo isn’t great, but if you click on it, it reduces and gives a general idea of the foot.
Martin, any idea where I could find two of these rubber pads?
Jeff, I'm sure, I can find a good used pair in the dungeons. Drop me an email.
I can supply rubber feet for Beomaster 700K, 900M, 900K, 901, 1100, 1400, 1500 and derivate Beocenter modelsas nice reproductions.
