beocord 6500 sound when playing
olvisab
Posts 1,391
olvisab Posted: Sat, Nov 3 2012 4:55 PM
Hello everybody
My beocord 6500 makes a sound when it plays.Like a "tic tic tic".This sound is louder and faster if I use the auto reverse function.
Everything works perfectly.
Could you please tell me where this noise could come from?
Best regards
olivier
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Vintage_B&O
Germany
Posts 303
I have the same problem. Just changed all belts.
Has anybody an idea, what problem this might me?
trackbeo
Posts 644
trackbeo replied on Wed, Nov 4 2020 11:00 PM
My guess from prior experience with cassettes only, and not from having repaired a Beo deck: Old cassettes.  If you look at the reel while it is turning, you'll see the smaller (usually take-up) reel actually twisting or rocking a tiny bit as it rotates, making the noise each revolution, as it hits inside the plastic shell.  (This is analogous to the repeated "swipe" sound that reel-to-reel tape recorders made when the tape wasn't centered between the plastic hubs, or the hubs had warped.)
You might be able to eliminate the noise by pressing slightly on the take-up side of the cassette shell.  Never having done a repair, wild-ass guess: If it happens on *all* your tapes, even new(-ish) ones, then maybe there is a mechanical adjustment I don't know about that is making sure the cassette is level in the well, or the deck's clutch/hub-drive mechanism isn't 100% vertical to the deck well.  Hopefully someone with more experience can suggest a repair, but I can say that *many* of my tapes made that noise, in many brands of decks, before I threw the whole mess away...
Vintage_B&O
Germany
Posts 303
Thank you for your answer.
But unfortunetly it is not the cassette. Every time I press turn an the deck runs rewind, I hear this clicked sound. Might be a problem with the gears or something like this. Maybe I have made a mistake changing the belts.
I think I have to reopen it :-) But it is difficult to test.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Nov 5 2020 11:41 AM
It's a question of factory tolerances in some decks, where a reel brake comes to close to catching.
I like to solve it by glueing in a thin piece of plastic sheet or similar on this edge:
Vintage_B&O
Germany
Posts 303
I don't unterstand what you mean. Kan you explain it please?
Vintage_B&O
Germany
Posts 303
This is the clicking-sound I hear.
https://youtu.be/fyX_5b6eUxQ
Page 1 of 1 (7 items) | RSS
