Hi all, I have just purchased a Beovision 8-32 in very good condition for the Kitchen, all seams to be working well apart from the Program guide. Upon loading the Guide It displays very little info or none at all. If I go a page down then back up it does display the info. Is my module in need of an update, or do I need to re-tune the DVB ? any advise would be much appreciated.
Hi - I think you just need to leave it on for a while - when mine is connected to an aerial it seems to take an age
Thanks for the reply, will try leaving it on, I was also powering it off at the mains, not sure if this had anything to do with it.
