Hi all,
My BG7000 has gotten a problem: the tonearm carriage won't move. When pressintgplay, the platter spins as usual, but the tonearm is stuck at 0 positiion and a ticking sound can be heard.
The carriage can be moved by hand - there is no resistance of any kind, it feels like it usually does - but the motor isn't able to move it.
Is this something that I might be able to fix myself? Any suggestions?
Thanks,
Henrik
Ah, I just found this old thread - I'll read it through, that'll probably solve my problem :) http://archivedarchivedforum2.beoworld.org/forums/t/35376.aspx
Sorry about that, I forgot to search the old forum!
Almost done! I just wish I had two more hands - the last part of the threading process (hooking the springy end of the wire on to my new hook (a screw)) is really tricky, at least for me! :)
Allow me to show how I once fixed a similar problem:
http://archivedforum2.beoworld.org/forums/t/926.aspx
Kind regards
Steffen
Thanks for the advice, Steffen, i found that thread and a similar one and now my BG7000 is playing again!
