Hi - can anyone advise re the following?
I've a Beolab 3500 in a multi room set up - and the clock is showing as one hour away from the actual time. I am not aware of any way you can directly programme the Beolab clock itself - I believe the time shown comes from the master unit in the system?
I have a Moment / Horizon set with a NL ML Converter which has integrated into a multiroom set up all of my various older ML products - which includes a Beovison 8-32.
So the question is - which is the master unit driving the clock's time no the 3500 - if it's the Moment / Horizon I'd expect these to have their time updated automatically as their online items - if it's the Beovision 8 I can't seem to find the menu option to allow for the time to be altered.
Any thoughts / suggestions gratefully received
thanks v much
I´m quite sure its neither of the units you mentioned that sets the time.
It was a while since I had the NL/ML converter, but I recall that it has a clock.
Can you check what time the NL/ML converter is set at?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
thanks v much - I'll take a look when I'm at home....forgive the ignorance but how does one access the nl ml to get this type of info?
To access the Web Interface in the BeoLink Converter NL/ML:
Connect a computer directly to the BeoLink Converter NL/ML via the Internet Browser - IP-address: 169.254.11.22.- Disconnect the mains, reconnect the mains and wait until the LED indicator behind the socket panel cover stops flashing green. - Enter the IP-address in the Internet browser.- The default user name: ‘admin’.- The default password: ‘admin’.
No computer at hand:
’Connection via an iPad/iPhone:
An iPad/iPhone can be used to access the Web Interface in the BeoLink NL/ML Converter.
- Open the Internet Browser on the iPad/iPhone (‘Safari’).
- Enter ‘BLC-’ followed by the BeoLink Converter NL/ML serial number: [BLC-XXXXXXXX.local].‘
You should be able to see he time there.
I used to have this problem, and I never got to the bottom of it. It just went away after a while. However, in hindsight, it went away after my BLC was decommissioned by a lightening strike. I think you guys are on to something...
Stan
On old ML systems, the clock was set in the Video Master (if there was one connected) or the audio master.
Your system comprises BeoVision 8, BeoVision Horizon and BeoSound Moment and none of these models have a clock hence there is no menu on any of your products to set the time.
In this instance the time has to be set within the NL/ML convertor. In addition the correct time zone has to be set to ensure the hour automatically adjusts for daylight saving.
Hope that helps.
Regards
Opman
thanks everyone - i will try to get to the bottom of this and report back!
