hi everyone,
justnought a ml/Nl Converter to integrate my beloved Beosound 9000 to my beovision v1 und my also new beosound core.
I cannot find it on the beo webpage.
anyone here?
thank you in advance!
How about this:
http://mlgw.bang-olufsen.dk/source/
Oops - meant:
https://www.bang-olufsen.com/~/mediaV3/Files/user-guides/BeoLinkConverter/BeoLink_Converter.pdf
If, in the unlikely event, you need more info 😂 Martin has the installation guide on his Dropbox;
https://www.dropbox.com/s/ihmcjen1p0bmj81/BLC_NL-ML%20Installation%20Guide%20Ver.%201.2.pdf?dl=1
Thank you, that was the document I was looking for.
everything works now!
On Page 5, the installation guide refers to a second installation guide for the NL/ML Converter for the use case without Master Link (ergo using the NL/ML converter as a BeoLink Active:
BeoLink Converter NL/ML Installation Guide: Note! To read more about this Network Link setup, see the Network Link setup (without Master Link) Installation Guide.
Does anyone have access to this second Installation Guide?
Thank you for providing the document. Is this the most recent version?
Kind regards,Luc
steelpan:Hi, Thank you for providing the document. Is this the most recent version? Kind regards,Luc
edit: see the next post for the download (thanks MM)
Alternatively you can also find it here:
https://www.manualslib.com/manual/2021215/Bang-And-Olufsen-Beolink-Nl-Ml.html#manual
