WHEN I PLACE A 180GRAM LP ON THE TURNTABLE ITS EXTRA THICK AND THE ARM IS LOW OK FOR NORMAL VINYL BUT THE STYLUS WILL HIT THE EDGE OF THE LP. I AM NOT ABLE TO LOWER THE TURNTABLE USING THE 3 SCREWS ITS AS LOW AS POSSIBLE. THE ARM JUST SEEMS TOO LOW. HELP!
tracker:WHEN I PLACE A 180GRAM LP ON THE TURNTABLE ITS EXTRA THICK AND THE ARM IS LOW OK FOR NORMAL VINYL BUT THE STYLUS WILL HIT THE EDGE OF THE LP. I AM NOT ABLE TO LOWER THE TURNTABLE USING THE 3 SCREWS ITS AS LOW AS POSSIBLE. THE ARM JUST SEEMS TOO LOW. HELP!
Why the capitals?
POOR EYESIGHT EVEN WITH SPECS
The post you replied to was lower case...
The leaf spring adjustments sets the height of the whole subchassis.The carriage (and tonearm) is on the subchassis, so adjusting the deck height has no influence on thetonearms height in relation to the platter.180g records are not standard, so you should never adjust your deck to suit those, instead let them remain an excemption.- But the deck should be able play them nonetheless, so I think there must be something wrong with the ground-up adjustmentof the deck.It's all in the servicemanual.
Oh, and using capitals is considered shouting.
thankyou Martin for your advice. Peter
thankyou for your advice.
