I got a beocenter 9500 but the cassette player is chewing up the cassettes.
Visibly I can see the two middle parts that roll the tape are not identical one needs new part. See photos below.
What is this part called? Where do I get it from and is it a speacial way to fix it?
Will this fix the cassette chewing up issue or is there another reason for it?
The one on left is missing
Missing is the tri-wing, a spring and a small locking ring.Yes, it could damage tapes like that. It will most likely also need new belt(s), cleaning and fresh lubrication.Apart from the missing parts all very common.
Maritn
I brought stuff from you before can i buy these of you?
I am sure I can find something in the dungeons.Email me.
Lost your email.
This might just be scrap lying around for you but huge value to me!
That's a shame.Click on my name above my avatar and then click on send email or start conversation.Scrap is easily recognized. It is more than about 3-4 years old and has either Philips or some japanese brand name stamped on it.If I considered B&O parts scrap, I wouldn't have had considerably more than enough of it to make most sane people worry about me.
