BV7 without center speaker
steve1977
Posts 911
steve1977 Posted: Tue, Jun 26 2018 6:09 AM
I am currently using my BV7 in surround setup with 4 BL800 and 1 BL2. I am not 100% happy as sometimes the wrong audio signals are very loud making it hard to watch movies. I read others feel the same.
I am thinking whether I should switch away from my 5.1 setup and instead go with 2.0 or 2.1.
I was wondering whether anyone has a setup with a BV7 without center speaker. Is it easy to remove the center speaker and how does the BV looks like once removed the center (I have a floor stand).
Rob - Danish AV
Melbourne
Posts 376
It would look fine, just the panel may look too high without th speakers.
perhaps just disconnect or disable the Center speaker and leave it there?
kallasr
Germany
Posts 2,562
kallasr replied on Tue, Jun 26 2018 9:45 PM
I think you should be able to setup your speakers in a way that satisfies you. Your settings are probably not perfect.
Always use a center speaker!
Ralf
Page 1 of 1 (3 items) | RSS
