Is there a reference or a resource that will show what Mk / Versions have been released and what the differences of those MKs are?
I know that most of us are BeoNerds (TM) and may know. Perhaps it might be a start of a reference?
I have seen on Beocentral that there is "type" numbers. But do types mean "MK?
eg with the BV Avant below does this mean it is up to Mk 5 ("E")
(2014-2017)
Type numbers: 9671, 9672, 9673, 9674, 9675
Often, but it's not a general rule.The type numbers are typically also used to refer to territory specific versions.Martin
