Hi guys. A question for Eclipse owners regarding external HDD for recording. I have had several different portable drives connected and all of them are making high pitch noises from being constantly read by the TVs software. It is driving me nuts. Have anybody experiencing the same? I have also tried to connect a USB flash drive instead but the TV tells me that it does not support it for recording
BeoVision Eclipse 55, BeoPlay S8 (sub+rears), BeoPlay A9 MKII (living room), BeoVision Avant 32 DVD (retro gaming, basement), BeoLab 4000 (entertainment room, basement), BeoSound 8 (workshop), 2x BeoPlay S3 (PC), BeoPlay A1, BeoPlay H2/H3 (on the go)
Invest in an SSD!
Have you tried if the Eclipse will accept a SSD? It is also an expensive solution should I want 500 gigabyte.
I've had the same anoying noise issue. I've change my WD harddisk to a SSD-drive thrue USB. I't just works perfect.
Regards
Jan Præst
BeoLap 17, BeoLap 3500, Beosound 35, BeoSystem 4, BeoPlay A2 Active, Beovision Eclipse 55, Beoplay E8 2.0, Beolap 19
Thank you for confirming that SSD works, Jan
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Same here Miki - Seagate portable HDD 1tb. Noiseless to all intents and purposes.
Beolab 18 (oak, white and walnut), Beolab 19 (white), Beolab 17 (aluminium), Beovision Eclipse 55, Beoplay E8 (charcoal sand), Beoplay H9i (black), a house full of Sonos, Synology NAS, Spotify user.
