BV7 to Vero4k
Scott Needham
Paris, France
Posts 217
Scott Needham Posted: Fri, Jul 6 2018 12:04 AM
Hello,
I recently purchased a Vero 4k as a media player. It has a built-in IR receiver but also a port (3.5mm jack) for an external receiver.
I currently use the PUC blaster on my BV7 to send IR to the Vero 4k receiver. However taping an emitter to a receiver seems like an inelegant solution.
Would it be feasible to just use a wire to transmit from jack to jack ?  It seems like it should but I know nothing about IR...
Thanks for any advice and/or information about the B&0 IR blaster.
- Scott
lawrencejmcook
Posts 742
Hi Scott,
Sending the commands via jack plug is possible. If you look in the BeoIntegration manual I think there are pictures of Oppo Blu-Ray players being controlled that way.
Sorry, not sure how to add a link here.
Page 1 of 1 (2 items) | RSS
