Is it possible to delete the three pre programmed stand positions - Standby - Audio - Video?
it is so annoying that the tv turns when go from the tv to netradio!
You can't 'delete' them as such, but you can make them all the same in the Stand Settings menu...
I actually quite like it when the TV moves between sources. Reminds me the thing is actually working
Lee
9 LEE: You can't 'delete' them as such, but you can make them all the same in the Stand Settings menu... I actually quite like it when the TV moves between sources. Reminds me the thing is actually working Lee
I like them too - missing so much on Avant NG...
Elmar
I really hate that function. So if I sit in my sofa and are watching tv and are thinking: What is on the radio - it turns away! I must quick choose stand and turn it the same way again!
They got rid of this function later on
But with your BV11, like my Avant Gen 1, the best thing is to make them the same stand setting and then there is no issue.
