Beogram 4002 pros and cons AC vs DC motor?
This post has 14 Replies | 0 Followers
Beo_Jean
QC, Canada
Posts 334
Beo_Jean Posted: Sat, Jul 7 2018 8:00 PM
Hi everyone!
I already own a Beogram 4002 in good working order which is the DC motor version.
I'm contemplating the AC motor instead but wondering if I'm going to gain something?
Waiting for your inputs!
Thanks!
Charles
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Jul 7 2018 8:40 PM
Salut Charles !
Having both AC (with heavy platter) and DC versions, I’d say there isn’t much to it. The (excellent) Japanese DC motor has brushes and it’s therefore not as silent as the AC Swiss motor. It is probably less durable as well.
Electronics tend to be less complicated with the DC version too.
That said, many swear by DC motors sound wise, even replacing synchronous motors with those on Linn and Thorens turntables, but frankly the so-called improvement remains to be proven—at least to my own ears!
But then again, any B&O completist should have both, shouldn’t they? Stick out tongue
Jacques
sonavor
Texas, United States
Posts 3,732
sonavor replied on Sat, Jul 7 2018 10:11 PM
Both AC and DC motor versions of the Beogram 400x turntables are great once the motors have been rebuilt. If the motors are still original then the oil in their bearings have to be about gone by now. I have had Beolover restore both AC and DC motors for me and they perform like new again.
As Jacques said, if you consider yourself a B&O completist then you really should have both types :-).
Beo_Jean
QC, Canada
Posts 334
Beo_Jean replied on Sun, Jul 8 2018 12:43 PM
I'll skip my turn for owning two BG since I consider myself enough B&O... compulsive...
My intent is to send the motor to Beolover and put the money on the table I want to keep.
If, sound wise, they are both "equivalent", I'll stick to the one I have.
Thanks a lot for your inputs guys, much appreciated as always.
Charles
sonavor
Posts 3,732
sonavor replied on Sun, Jul 8 2018 1:35 PM
The biggest factor in how it sounds of course is the cartridge so make sure and allocate money for that component.
Beo_Jean
QC, Canada
Posts 334
it has an MMC6000 but I don't know the wear of the stylus though.
hamacbleu
Québec, Canada
Posts 194
hamacbleu replied on Sat, Jul 21 2018 6:29 PM
I would also mention that the ribs on the platter of the AC version are thinner than the one with the independent subplatter (4002 DC and 4004), making it aesthetically more like the 4000. It might not be a big concern though! However, that detail has always bugged me!
Guillaume
chartz
Burgundy, France
Posts 4,171
chartz replied on Sun, Jul 22 2018 10:03 AM
That's right. The AC BG 4002’s had a 4000 platter without the painted strobe markings. I never quite understood why B&O used fragile paint as others - the Duals, Technics et al, were using cast markings.
Jacques
politician
Posts 180
I believe that there are also AC and DC versions of the Beogram 6000. What's the easiest way to tell which version I have? Is it by looking at the ribs on the platter? Could anyone post pictures of the two different versions so I know what I'm looking for?
hamacbleu
Québec, Canada
Posts 194
hamacbleu replied on Sun, Jul 22 2018 11:42 PM
For your curiosity, here's an old post with a nice pictures showing the subtle difference between the two kind of platters :
https://archivedarchivedforum2.beoworld.org/forums/p/35223/292539.aspx
The one with the thinner ribs (Beogram 4000, 4002 early and 6000 early) is made in one heavy block. Later types have a black and smaller subplatter, seperated from the main aluminum platter above it.
I don't know, however, if the switch between AC and DC followed exactly this manufacturing difference.
Type number for these models start with 55 followed by two numbers. on the 6000, I think the third number can be "0" or "1". The fourth number, if it follows the 4002 structure, is a market designation (GB, USA).
If the third number is "0" as in type 5502 or 5505, then, the deck is probably the AC version.
The best way to confirm would be to look at the electronics : The AC version has four big capacitors, right above the motor. The DC version as only one.
Guillaume
politician
Posts 180
Very useful! Thanks hamacbleu!
sonavor
Posts 3,732
sonavor replied on Mon, Jul 23 2018 6:53 PM
Bang & Olufsen did expect a Beogram owner to change the platter belt so access to the inside was made pretty easy. Pull out on the wood trim and the deck will be unlocked. Then you can lift off the aluminum deck plates. I advise to remove the phono cartridge before doing this or, at the very least, attach the protective cap on the cartridge. The deck lid could bump in the stylus.
Once exposed you can see what type the motor is. However, as others have mentioned, I believe all of the AC platter motor Beogram 400x decks have the heavier, one-piece platter.
As for advantages of one over the other I wouldn't say there really is. I have a number of the Beogram 400x turntables and when they are restored they all perform magnificently. The key is making sure they are maintained and well taken care of ... and having a good phono cartridge.
Beo_Jean
QC, Canada
Posts 334
Thanks everyone!
Piaf
Victoria, British Columbia Canada
Posts 2,639
Piaf replied on Fri, Aug 24 2018 9:40 PM
The MMC6000 is simply a superb stylus, I have one on my Beogram 8000, which gets daily use.
Wear makes a considerable difference, but suspension hardening is the killer. (or so I am told, as I have not experienced this....yet)
Do note the MMC6000 has a well earned reputation as the fantastic dusk collector. THIS is can confirm.
Jeff
Beogram 4000, Beogram 4002, Beogram 4004, Beogram 8000, Beogram 8002, Beogram 1602. Beogram 4500 CD player, B&O CDX player, Beocord 4500, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 8004, Beocord 9000, Beomaster 1000, Beomaster 1600, Beomaster 2400.2, Beomaster 2400.2, Beomaster 4400, Beomaster 4500, Beolab 5000, Beomaster 5000, BeoCenter 9000. BeoSound Century,  S-45.2, S-45.2, S-75, S-75, M-75, M-100, MC 120.2 speakers; B&O Illuminated Sign (with crown & red logo). B&O grey & black Illuminated Sign, B&O black Plexiglas dealer sign, B&O ash tray, B&O (Orrefors) dealer award vase,  B&O Beotime Clock. Navy blue B&O baseball cap, B&O T-shirt X2, B&O black ball point pen, B&O Retail Management Binder
chartz
Burgundy, France
Posts 4,171
chartz replied on Sun, Aug 26 2018 3:53 PM
Hi everyone!
Worn out MMC carts suffer a drastic treble loss: the tip looks good, the suspension looks fine and yet they sound dull dull dull.
Nice to see that all beofriends are still here by the way.
Jacques
Page 1 of 1 (15 items) | RSS
