I have Beosound 9000 which stopped reading CD for few month now. After spinning about 2mm each time unit would go into stand by mode. (tried laser cleaning).Assuming this is known Laster issue I let unit alone since I barely use it.Yesterday decided to check it again. I removed it from floor stand, placed it flat on the table and adjusted position screws. When tried to load CD I notice that glass door would stop half way. I had to help it in order to open door fully.I'm guessing door belt can be adjusted/replaced?Could this be relevant to CD issue?
Thanks!
BeoSystem 3BeoSound 9000BeoLab 8000/6000/4000/3500/BL2PlayMakerBeoCenter 9300BeoGram 5500BeoCom1/1600 + BeoTalk 1200BeoCord vx5500
Unfortunately, there is no belt. Just motor and gear, which comes as one unit. Not sure, whether B&O is still providing these. The unit alone cost above 400 Euros some time ago. Won't be an inexpensive fix, I guess. Again unfortunately, I don't think that the CD issue has got anything to do with it.
Kai
