I just bought a BeoGram 1900 which I thought was in good working condition. However, when I play a 45rpm record the speed is way to slow. Sounds more like it's playing at 33rpm...
Is this a known issue and an easy fix?
Many thanks,
Jesper
Does the idler wheel jump to the higher step on the motor pulley when you play at 45RPM?If not, something in the mech is wrong or has seized.
Thanks Martin, I'll have a look tonight
Hi Martin, I've just checked and the idler wheel doesn't jump to the higher step on the motor pulley when I play at 45rpm.
In your experience, is that something that can be fixed?
Many thanks
