So, I have just got my new Beosound5 and here is a little review of it.
I did the set up by myself which was not that difficult with some little help from this lovely forum!
It's connected through masterlink to my beovision7 and everything works perfect.
When I press CD on the BEO4 the Tv turns off and the Beosound5 turns on and uses speaker4 instead of 5.
The MOTS took overnight to analyze my music but it is worth the wait.
I have an airport express connected to the BM5 so all the syncing is wireless and done with drag and drop from iTunes.
MARKFS: So, I have just got my new Beosound5 and here is a little review of it. I did the set up by myself which was not that difficult with some little help from this lovely forum! It's connected through masterlink to my beovision7 and everything works perfect. When I press CD on the BEO4 the Tv turns off and the Beosound5 turns on and uses speaker4 instead of 5. The MOTS took overnight to analyze my music but it is worth the wait. I have an airport express connected to the BM5 so all the syncing is wireless and done with drag and drop from iTunes.
Very nice Mark - thanks for the pictures !
BeoNut since '75
I went for the Black version.
Yes i mounted it myself, and it took around an hour to figure everything out.
It's clear that Bang & Olufsen doesn't want the buyer to set things up by our own, as the guides are very limited :)!
I thinking about buying a beo6 for the system. Has anyone tried how that works?
Yes, I have the BEO6 and the WIFI function is OK. You can scroll artists and albums and the cover shows up on the little screen when playing. The WIFI sometimes has to think a little before it wakes up but that could depend on my network. Brgds Ingvar
Earlier; BV 10-46, 2*BL3, BM5/BS5, BS9000, BL8000, BV7-32, MX7000, Beoport, Beocord 8000, MX4002, BL2000, Beocom1, Beotalk1200
MARKFS:I went for the Black version. Yes i mounted it myself, and it took around an hour to figure everything out. It's clear that Bang & Olufsen doesn't want the buyer to set things up by our own, as the guides are very limited :)! I thinking about buying a beo6 for the system. Has anyone tried how that works?
We got the Beo6 after using the BS5 for a while. In my opinion the beo6 is neccesary if you want to change music from your couch.. With the beo4 you cant do anything exept hanging source.. The only downside with the beo6 is that it is slow, but most b&o are a bit slow..
I also have my bs5 connected to my tv, I use two speaker setup when listening to music. I also used the cd command. My delaer told me to change from cd on the bs5 to a.mem - then the system dont start the tv for listening to music..
Nice to see someones new exciting purchase unboxed and set up :-) Congratulations!
Olly
Okay, I think I might need to consider buying the beo6, but I'm not sure yet :)
I don't know why you had to change it to a.mem?
I have changed my to CD, and when I press CD on the Beo4, my four speakers turn on. The last one (the center speaker in my beovision 7) stays off, and the TV never turns on?
When I turn on the TV, it shifts to speaker 5, and the TV tilts and turns to its video position.
You can change which speakers that you want to turn on when you are listening to audio in the Tv menu.
