[SOLVED] MCL 2AV (2031) S.W. 2.1 programming
Aleksei
Estonia
Posts 22
Aleksei Posted: Fri, Nov 9 2012 5:14 PM
Dear colleagues,
I have MCL 2AV (2031) SW2.1 and IR Transciever (2047) SW2.0
I would like to connect it to my beomaster 5500 to get extra audio inputs.
Please help me with programming MCL 2AV.
Many thanks in advance,
Aleksei
Aleksei
Vienna
make an educated guess
Posts 1,090
Vienna replied on Sat, Nov 10 2012 9:26 AM
Aleksei:
The inputs on the MCL 2AV are "additional local inputs" in a link-room with active speakers.
Sources connected to these inputs can only be used locally (in this room), they  can't be
"exported" to other link-rooms (to other MCL  2AV's)  nor can they be "routed back" to the BM 5500.
Some information about MCL and option setting (programming) you'll find in the BeoTech section of this site:
http://www.beoworld.org/beotech/index.htm
http://www.beoworld.org/beotech/options6.htm
Aleksei
Estonia
Posts 22
Aleksei replied on Fri, Apr 26 2013 2:31 PM
Hi Vienna,
Thanks for your replay.
I think if I connect MCL 2AV PoweLink signal outputs pins with BM5500 AUX input pins it will work for me. At the moment I have connected with same mode my Beosystem AV 7000 and Beomaster 5500 and it works well as extended inputs.
My main problem, that I can't find programming guide for MCL 2AV. As soon I'm not a first owner of MCL 2AV, I don't know in which mode it will worked.
Best regards,
Aleksei
RaMaBo
near Munich
Posts 626
RaMaBo replied on Fri, Apr 26 2013 4:50 PM
Hi Aleksei,
try this link to the archived forum.
You should be able to open the ports of the MCL 2AV with <SHIFT>, <RADIO>, <6> or <7> with a Beolink 1000.
But you might get a problem because the powerlink output of the MCL 2AV is not at fixed level but variable. If your MCL2AV is in the same room as your Beomaster 5500 changing the volume can work on the BM5500 _and_ on the MCL 2AV.
Regards
Ralph-Marcus
Ralph-Marcus
Aleksei
Estonia
Posts 22
Aleksei replied on Sun, May 5 2013 2:58 PM
Hi Ralph-Marcus,
Thank you for solution. This is exactly, what I wanted.
Volume control not a problem for me, because I can bypas the volume control IC's TC9177P.
Many thanks for assistance,
Aleksei
Aleksei
BeoHut
Posts 482
BeoHut replied on Sun, May 5 2013 6:14 PM
Aleksei:
Or put the ML2AV in Option 4 and use the LINK-command to select other sources and do the volumecontrol from the ML2AV. No bypasses needed that way.
Page 1 of 1 (6 items) | RSS
