Can I edit this as a non privileged user ?
Answer is yes I can..
Regards
How how did you edit your post
Eclipse 65V1-32Beosound M5Essence MK2BLI
Seanie_230: How how did you edit your post
DITTO!
+1
How did you edit it?
Click the MORE button on the right and you should see EDIT
Regards Keith....
EdouardG: +1 How did you edit it?
+11
Vähintään yhdeksänkymmentä prosenttia suomalainen!
Keith Saunders: Click the MORE button on the right and you should see EDIT
I only see this...
Okay, but it doesn't appear on my original post...
Jacques
Ahhh that did not appear before
Excellent
Present!
Thanks!
++++EDIT++++
testing
Works!
Present in ONLY this thread? CACHE cleanse?
burantek: CACHE cleanse?
CACHE cleanse?
Geekspeak not heard on BBT yet. Shall I write Chuck Lorre?
EDIT
Test
EDIT 2
Test successful.
Comment: posting is near instantaneous. Me likey.
No edit option for me in a previous post, will try again
EDIT: It's there now!
If you think nobody cares, try missing a couple of payments.
Stonk: No edit option for me in a previous post, will try again EDIT: It's there now!
It appeared on my screen as well. Thanks, Keith!
Must try that, too!
EDIT: yes, it works!
beocool: Stonk: No edit option for me in a previous post, will try again EDIT: It's there now! It appeared on my screen as well. Thanks, Keith!
It doesn't appear if I try it on the snow! thread in the lifestyle forum... It seems to work fine on this thread. Any ideas?
It worked in the another thread for me just fine. I'll check this one momentarily.
EDIT: Success!
Beo4 'til I die!
Edit's back for me too!!
Regards Graham
Works for me as well! At last!
