Beogram 4000. Problem #2: Speed changes from 33 to 45 while playing
This post has 5 Replies | 2 Followers
alysvand
Posts 6
alysvand Posted: Thu, Mar 8 2012 6:20 PM
It happens when the tonearme reaches halfway(or typically 7 inches out)Is there an easy fix for this?
Step1
Manchester, UK
Posts 1,268
Step1 replied on Thu, Mar 8 2012 10:32 PM
Oh sounds interesting! Sounds like an inhibit line is missing somewhere that should prevent this from happening when playing a record, although maybe that is simplifying the issue somewhat.... I assume the player works normally in all other respects, and that it is at exactly the same spot? What happens if you lift the arm and reset just before the point at which the speed normally changes?
Olly
alysvand
Posts 6
If you just hit the on-button this happens every time. But you can avoid it by hitting the on button and the the 33 button right after.
Step1
Manchester, UK
Posts 1,268
Step1 replied on Fri, Mar 9 2012 9:07 AM
ok I am confused now, so normally with a 12 / 10" record the player will cue up normally and play at 33 until the arm reaches the point at which it would drop on the lead in grooves of a 7" record, thereafter the indicator and speed switches to 45...?
However, if you press on, then hit 33 straight after it will continue as above, but will not change to 45 rpm and complete the record?
Olly
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Mar 9 2012 10:00 AM
Yes this is confusing!
Can you make a video?
Jacques
alysvand
Posts 6
alysvand replied on Fri, Mar 9 2012 10:18 AM
Step1:
Excactly! I know. It's very strange indeed.
Page 1 of 1 (6 items) | RSS
