Beovox P45 wall mount hardware
This post has 11 Replies | 1 Follower
sunnbumm
Posts 8
sunnbumm Posted: Sat, Nov 10 2012 9:56 PM
I stumbled on a set of P45s this weekend without the hardware. Seem to be in great shape but I am having  a hard time finding information about how these gems mount to the wall. Even a photo of the hardware and maybe some dimensions so I can Fabricate new ones. Better yet, if anyone has some laying around?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Nov 11 2012 7:39 AM
Welcome to Beoworld !
Brackets are ready at the back for both horizontal and vertical hanging.
Put two solid screws in the wall and hang the speakers like you would a painting.
There's no addtional hardware.
Rich
Orlando, Florida, USA
Posts 2,598
Rich replied on Fri, Mar 1 2013 5:49 PM
Can I assume this is also true of P30s?
Dillen
Posts 13,191
Dillen replied on Fri, Mar 1 2013 5:56 PM
Yes.
Søren Mexico
Mexico City
Posts 6,411
The speakers has 6 plastic inserts, you can hang the the speakers with any 2 of these,using top or middle you can change the angle, depending on listening position, make sure to get the speaker as close to the wall as possible, this will give the best reflection (best sound).
sunnbumm
Posts 8
  1. Thanks, great help! Love the speakers, now to find a place to mount them.
Dillen
Posts 13,191
Dillen replied on Sun, Mar 3 2013 6:03 AM
And don't fit them too high up on the wall.
Ideally (sonically), they should be at ear-height when you are sitting and listening, which normally
results in a surprisingly low mount.
Rich
Posts 2,598
Rich replied on Mon, Mar 4 2013 2:22 AM
Dillen:
Yes.
Thanks, Martin.
My P30s will be hung on a wall in the garage. I will mainly listen while standing and working in the garage. As such I imagine my P30s will end up rather high on the wall in the end, but of course I will try multiple setups (as I always do).
Lanny
Czech Republic
Posts 9
Lanny replied on Mon, Jun 23 2014 12:56 PM
Sorry for the intrusion but I have a pair of P45 which I want to start using again :) Do you know where I could buy the cables which on one side plug into the speaker and on the other into a System 5000 receiver?
Steffen
Denmark
Posts 1,408
Steffen replied on Mon, Jun 23 2014 11:08 PM
You mean with DIN plugs in both ends? First of all - try asking your local B&O dealer.
- or ask Steve at Sounds Heavenly  (just look at the ad below)
Btw... Doesn't B&O have a factory in the Czech Republic..? Maybe  you could ask them... (or maybe not. They're probably too busy fixing the Avant assembly line) Whistle
No -better ask in a B&O shop - or Steve.
the_o_master
Posts 856
You can buy the 2 pole DIN plugs for both sides of cable in any electronic shop, also in Conrad or even OBI, Baumax, Bauhaus...
Vintage Bang & Olufsen
Rich
Posts 2,598
Rich replied on Tue, Jun 24 2014 10:50 PM
Take care of the woofers before you do anything else!
Page 1 of 1 (12 items) | RSS
