can beosound 5 encore work with blu ray play?
This post has 17 Replies | 2 Followers
mivsbai
Posts 77
mivsbai Posted: Sat, Nov 10 2012 11:55 PM
I have just got a pair of beolab 3, and I am considering to buy a beosound encore to pair with my bl3s. I am sure the bs5 encore should be very good for music. But I also want to connect bs5 encore to my blu ray player for watching movies in 2.0 channel. I am not sure whether this is possible, from b&o's website, it does say bs5 encore can connect to any media player with line out. My blu ray player has optical out, coaxial out and analog audio out. Which 'out' should I connect?
If bs5 encore can work together with blu ray player,  I imagine the whole set up should be Blu ray player connect to TV through HDMI for picture, and Blu ray player connect to bs5 encore for sound. In this way, would the sound and picture 'match' each other at same time? Would it be a delay for sound, as the sound is processed be bs5 encore not Blu ray player.
Many thanks
mbee
Paris, France
Posts 1,842
mbee replied on Sat, Nov 10 2012 11:58 PM
Impossible, the will be a delay between sound and image.
mivsbai
Posts 77
mivsbai replied on Sun, Nov 11 2012 12:14 AM
Thanks for your quick reply.  So the bs5 encore is limited for audio only, no way to work together with blu ray player? It is a shame B&O doesn't have any replace product for beocenter 2.
Vienna
make an educated guess
Posts 1,090
Vienna replied on Sun, Nov 11 2012 1:21 AM
mbee:
If connected directly - yes.
A workaround could be:
- Connect the BD to your TV via HDMI
- TV-settings for digital sound to 2 channel
- Let the TV do the "sync-job"
- Most TVs have an optical out (TOSLINK)
- Use a decent stereo D/A converter to convert digital sound to analogue line
- Connect converter to AUX / Line-In of BeoSound Encore.
elephant
AU
Posts 8,219
elephant replied on Sun, Nov 11 2012 1:35 AM
Vienna:
mbee:
A pity that the PlayMaker does not have a PowerLink connection as well as the line in ....
BeoNut since '75
Vienna
Posts 1,090
Vienna replied on Sun, Nov 11 2012 1:51 AM
elephant:
The suggested workaround is based on the assumption "NON B&O TV - NO LINE OUT"
If it's a B&O TV you'll just need an 8 pin DIN/RJ45 <> Stereo 3,5mm Jack adapter cable connected to a Front-PL-Out .
elephant
AU
Posts 8,219
elephant replied on Sun, Nov 11 2012 4:22 AM
Vienna:
elephant:
Oh I was thinking of something that is not possible ...
+---- lineout --- TV
+=== Playmaker ---<=== BeoLabs
+--- powerlink --- BS5/BM5
And the Playmaker would sense which source was active TV or BS5 (or the DLNA, or the AirPlay)
BeoNut since '75
mivsbai
Posts 77
mivsbai replied on Sun, Nov 11 2012 11:00 AM
Hi Vienna, if let tv to do the sync job, would sound and image match each other? Would it be a delay as well? Have you tried this yourself?
thanks
Vienna
Posts 1,090
Vienna replied on Sun, Nov 11 2012 12:04 PM
elephant:
Dear friend,
I've used parts of the following solutions in different setups - but I never checked the
described setup as "complete system" -  so this are merely "theoretical" thoughs.
- "Line-Out" of a non B&O TV (if available - otherwise workaround using D/A converter)
   via RCA/Cinch<> RCA/Cinch-cable
-  if it's a B&O TV,  "Special Adapter" DIN/RJ45 <> 2xRCA/Cinch plug from PL-Front
to "Line In" of Playmaker
- Playmaker set to "fixed volume" + option setting to "A.OPT" "0" or "4"
  (to avoid IR conflicts between Encore and Playmaker when using "A.AUX")
- "Special Adapter" RJ45 <> 3,5mm mini jack (or 2 B&O cables, part# 6271216 + 6270433)
from Playmaker PL-Out  >>  3,5 AUX-In socket on BSD Encore
The Playmaker would auto-sense active source (TV=Line or DLNA/AirPlay)
Speakers would still be connected to the PL-Out of BSd Encore via Powerlink.
You'll have to select "A.AUX" via remote or manually to get the sound of your TV or from
streaming device.
But there is still a general problem to be resolved:
Since the sound processing in the BS Encore is digital, a delay will occur.
The TV also uses a delay to get picture an sound synchronous.
You'll have to adjust the the lip sync of your TV/Source to a lesser value.
If your TV does not offer a wide range to adjust lip-sync it is very likely
you won't get picture and sound synchronous.
PS: To avoid the "additional delay issue" caused by the BeoSound Encores digital
sound processing the Bosscom PowerLink-Switch could be used.
PL from Encore on one input, on the other TV or Playmaker with TV on Playmakers Line In .
beojeff
USA
Posts 2,012
beojeff replied on Sun, Nov 11 2012 2:14 PM
You need to look at the full BeoSound 5 with BeoMaster 5 for what you're trying to do. The BeoSound 5 Encore is intended strictly to be a standalone product. The BeoSound 5 with BeoMaster 5 is intended to connect with other products for MasterLink integration.
Vienna
Posts 1,090
Vienna replied on Sun, Nov 11 2012 8:02 PM
@ beojeff
Absolutely right, the most straightforward and easiest way to reach the goal would be a "classic" pure B&O A/V setup
using MasterLink componets. All speakers connected to the B&O TV, as this would solve all delay and lipsync issues.
A BeoSound/BeoMaster 5 full combo plus a BeoVision 7 or 10 (or a BeoVision 11 + NL/ML Converter) will be a nice
setup to drive a pair of BeoLab 3s.
I admit, some parts of the discussion between elefant and me are a bit off topic to the
original question "can beosound 5 encore work with blu ray play?"
Answer in a nutshell: I should be possible when using some unorthodox workarounds, but it's not recommended
- there are to many if and when to predict a satisfactory result.
beojeff
USA
Posts 2,012
beojeff replied on Sun, Nov 11 2012 8:30 PM
mivsbai:
I fully agree with you that it's a shame that B&O hasn't replaced the BeoCenter 2, upgrading it to a blu-ray player with HDMI. While I can't bring myself to part with my BeoCenter 2 because it's such a beautiful design, I never even use it anymore. The only time I touch it is to dust it. My BeoSound 5 has made CDs obsolete, the Net Radio on the BeoSound 5 has made standard radio (for me, anyway) obsolete, and my Samsung blu-ray player completely outperforms the BeoCenter 2 for playing DVDs. So what we're left with is Bang & Olufsen without a blu-ray player in its product line and a completely out-dated dvd player (i.e., BeoCenter 2) with inferior video when compared to blu-ray players' upscaling ability.
I know that the classic BeoSound 5 is quite a bit more in price than the Encore, but the features are really what you are looking for, especially if you plan to add link speakers in another room -- which you will once you've gotten the B&O addiction.
Millemissen
Flensborg, Denmark
Posts 14,680
The answer to the original question was already given - so I am just repeating:
Use a Bosscom PL Switch (or the http://almando.com/ - solution).
One input for the Encore - the other for the lineout of the tv (with the BRP  via HDMI)
As for the unused BC2 of beojeff:. sell it - do not wait - it will soon be worthless.
Or put it in a glasscabinet to avoid the dust on it!
Greetings Millemissen
benjnz
Posts 114
benjnz replied on Sun, Nov 11 2012 9:00 PM
So listening to all the issues we're going to be having moving between ML and the new link, digital distrubution to analogue in link rooms etc, I always wonder if anything like this would be of use?... http://www.felston.com/dd740/
mivsbai
Posts 77
mivsbai replied on Sun, Nov 11 2012 10:16 PM
@Millemissen @Vienna
So I guess the Bosscom PL switch can act like a bridge between tv and BS5 encore. And the sound and image can be synchronous with the help of Bosscom PL switch?  Even my TV doesn't have lip-sync adjustment? Am I right?
I assume the setup would be:
bl3s =>pl out from Bosscom PL switch
BS5 encore=> PL line in 2 from Bosscom PL switch
TV => line in 1 from Bosscom PL switch ( If the TV doesn't have line out, just use a high quality optical to analog converter)
BRP =>TV through HDMI
Btw, I do not own B&O tv and playmaker
mivsbai
Posts 77
Smile
Vienna
Posts 1,090
Vienna replied on Sun, Nov 11 2012 11:30 PM
mivsbai:
Am I right?
(If the TV doesn't have line out, just use a high quality optical to analog converter)
Big Smile  BINGO!
Vienna
Posts 1,090
Vienna replied on Mon, Nov 12 2012 12:30 AM
benjnz:
Yes, boxes like this one can help to solve specific delay issues - but there are no simple "one fits all" solutions in complex setups.
Page 1 of 1 (18 items) | RSS
